    A List of Shortcuts?
    12 Posts 10 Posters 3.4k Views 10 Watching
    • JClementsJ Offline
      JClements
      Hey Rossie:
      Hope all is going well for you ... has the "Big Chill" set in yet?
      I know about the export function. I did do that already; however, I know that somethings didn't come across properly. That's why I wanted a summary so I could spot any missing or misasigned stuff.
      John
        JClements
        Well I wasn't totally delusional. I found a List Shorts in the Help Menu for my SU5.
        It was placed there via a rubyscript which works in SU6 too.
        Now is there a ruby guru that could add a print list function to this?
        ShortcutsList.rb
        • Chris FullmerC Offline
          I think that you can copy and paste the text into a text document and print it that way. I thought I remember having dne that before.
          • AnssiA Offline
            Anssi
            Also, the file "Preferences.dat" that is created when you push the "export" button in the dialog, can be opened in a text editor like Notepad, and the shortcuts are listed there in a quite readable form.
            Anssi
            • EdsonE Offline
              Edson
              check this thread on the very same subject.
              http://www.mahfuz.arq.br
                Ah, yeah, Edson, thanks... I was really looking for this as a reference but could not find.
                  gata
                  Also http://sketchuptips.blogspot.com/2007/08/plugin-print-shortcuts.html
                    Jackson
                    I also noticed this recently when I exported my shortcuts to a colleague's PC. 90% of them came across fine, but a few didn't. Weird, this is one for the bug forum.
                    Jackson
                      Move it there then Jackson...
                      I haven't tried to export them yet so I don't know... πŸ˜’
                        GreenToaster
                        Here's a txt version of the "Introductory SketchUp Notes" I provide my students - these are the "default" shortcuts - you can easily change them to be whatever you want - there's also some additional information listed here as well - maybe this will help (& I hope I'm not infringing on any copyright laws by posting this):
                        start
                        To change units to decimal:
                        Window --> Model Info --> Units --> Format --> Decimal --> (close the dialog box)
                        To show toolbars:
                        View --> Toolbars --> Getting Started
                        View --> Toolbars --> Large Tool Set
                        View --> Toolbars --> Views
                        Note:
                        Status Bar – the long gray rectangular area at the bottom of the drawing area
                        Value Control Box – located on the right side of the status bar
                        Must press Enter to have a value accepted
                        Default Shortcuts:
                        T = Tools --> Tape measure
                        Space bar = Tools --> Select
                        S = Tools --> Scale
                        Q = Tools --> Rotate
                        P = Tools --> Push/Pull
                        B = Tools --> Paint Bucket
                        F = Tools --> Offset
                        M = Tools --> Move
                        E = Tools --> Eraser
                        CTRL + Z = Edit --> Undo
                        CTRL + T = Edit --> Select None
                        CTRL + A = Edit --> Select All
                        CTRL + Y = Edit --> Redo
                        CTRL + V = Edit --> Paste
                        G = Edit --> Make Component
                        Delete key = Edit --> Delete
                        CTRL + X = Edit --> Cut
                        CTRL + C = Edit --> Copy
                        R = Draw --> Rectangle
                        L = Draw --> Line
                        C = Draw --> Circle
                        A = Draw --> Arc
                        Z = Camera --> Zoom
                        H = Camera --> Pan
                        O = Camera --> Orbit
                        If you really want something you won't ever stop pursuing it.
