    A List of Shortcuts?
    12 Posts 10 Posters 3.4k Views 10 Watching
    • JClementsJ
      JClements
      Running SU6.
      I would have sworn in the Window > Preference > Shortcuts dialog there was an option to display and print a list of the active shortcuts.
      Or was this done via a ruby script?
      Anyone know?
      I'm installing SU6 on a new laptop and wanted to audit a summary of the shortcuts.
        Ross Macintosh
        Mr Clements, my old buddy!
        The Window>Preferences>Shortcuts panel does have an 'export' option that will allow you to sync your shortcuts for two computers. Export from one and import into the other and you'll be more "Insync" than a boy band.
        Regards, Ross
        • JClementsJ
          JClements
          Hey Rossie:
          Hope all is going well for you ... has the "Big Chill" set in yet?
          I know about the export function. I did do that already; however, I know that somethings didn't come across properly. That's why I wanted a summary so I could spot any missing or misasigned stuff.
          John
          • JClementsJ
            JClements
            Well I wasn't totally delusional. I found a List Shorts in the Help Menu for my SU5.
            It was placed there via a rubyscript which works in SU6 too.
            Now is there a ruby guru that could add a print list function to this?
            ShortcutsList.rb
            • Chris FullmerC
              I think that you can copy and paste the text into a text document and print it that way. I thought I remember having dne that before.
              • AnssiA
                Anssi
                Also, the file "Preferences.dat" that is created when you push the "export" button in the dialog, can be opened in a text editor like Notepad, and the shortcuts are listed there in a quite readable form.
                Anssi
                • EdsonE
                  Edson
                  check this thread on the very same subject.
                  http://www.mahfuz.arq.br
                  • GaieusG
                    Ah, yeah, Edson, thanks... I was really looking for this as a reference but could not find.
                    • G
                      gata
                      Also http://sketchuptips.blogspot.com/2007/08/plugin-print-shortcuts.html
                        Jackson
                        I also noticed this recently when I exported my shortcuts to a colleague's PC. 90% of them came across fine, but a few didn't. Weird, this is one for the bug forum.
                        Jackson
                        • GaieusG
                          Move it there then Jackson...
                          I haven't tried to export them yet so I don't know... πŸ˜’
                          • G
                            GreenToaster
                            Here's a txt version of the "Introductory SketchUp Notes" I provide my students - these are the "default" shortcuts - you can easily change them to be whatever you want - there's also some additional information listed here as well - maybe this will help (& I hope I'm not infringing on any copyright laws by posting this):
                            start
                            To change units to decimal:
                            Window --> Model Info --> Units --> Format --> Decimal --> (close the dialog box)
                            To show toolbars:
                            View --> Toolbars --> Getting Started
                            View --> Toolbars --> Large Tool Set
                            View --> Toolbars --> Views
                            Note:
                            Status Bar – the long gray rectangular area at the bottom of the drawing area
                            Value Control Box – located on the right side of the status bar
                            Must press Enter to have a value accepted
                            Default Shortcuts:
                            T = Tools --> Tape measure
                            Space bar = Tools --> Select
                            S = Tools --> Scale
                            Q = Tools --> Rotate
                            P = Tools --> Push/Pull
                            B = Tools --> Paint Bucket
                            F = Tools --> Offset
                            M = Tools --> Move
                            E = Tools --> Eraser
                            CTRL + Z = Edit --> Undo
                            CTRL + T = Edit --> Select None
                            CTRL + A = Edit --> Select All
                            CTRL + Y = Edit --> Redo
                            CTRL + V = Edit --> Paste
                            G = Edit --> Make Component
                            Delete key = Edit --> Delete
                            CTRL + X = Edit --> Cut
                            CTRL + C = Edit --> Copy
                            R = Draw --> Rectangle
                            L = Draw --> Line
                            C = Draw --> Circle
                            A = Draw --> Arc
                            Z = Camera --> Zoom
                            H = Camera --> Pan
                            O = Camera --> Orbit
                            If you really want something you won't ever stop pursuing it.
