    Soap skin question
    4 Posts 2 Posters 6.3k Views 2 Watching
    • I
      ianccc
      I haven't been able to fine a tutorial I understand on the Soap/Skin Bubble tool so appreciate any assistance on this.
      my question is this
      -I make my closed outline
      -click the Generate Soap Skin Icon
      -see a outline with squares (can type in the VCB a different value)
      -I select all and click the X/Y Icon and see the following
      EDIT TOOL: RUNNING SOAP SKIN RATIO
      RATIO X/Y: 30
      PRESSURE:
      -I can type in a value in the VCB and it changes the ratio value but nothing happens onscreen also the grid pattern that first appeared is not there
      -if I select all again and click on the Bubble Icon I can set the pressure but nothing happens
      I Do not have the ProVersion - could this be the problem
      any info appreciated
      ~ian
      • GaieusG
        Jan, when ahving entered the retio you want to apply (I think the default is 10) and you hit Enter, true that nothing seems to happen. Hit enter again and then the mesh really start.
        • I
          ianccc
          Thanks Gaieus
          that did the trick - is there any info on how the values in the VCB affect the outline
          does the Bubble blow up and Pressure suck in the outline
          Also how do I quickly remove the grid lines after I have applied a texture
          thanks
          ~ian
          • GaieusG
            It's always a kind of try and redo thing when I'm working with it (not too much).
            The lines are just simple edges of a tin which you should (not just can) smotth afterwards. Select the group (it comes out groupped) and go to the soften dialogue , check bot boxes and try sliding it slowly. There are often some "obnoxious" lines that don't want to smooth - you can do this with the Ctrl+Eraser tool while editing the group.
