    [Plugin] MoveIt
    53 Posts 28 Posters 49.1k Views 28 Watching
      Stu
      Thanks Jim,
      Now I understand [well sort of].
      As I mentioned, I have used nudge for a long time but find mover much more useful and easy to use. And I love the rotate function and its options. Used in combination with the x,y,z movements its pretty easy to get a random effect of , say, a soldier course of trees.
      Stu
      http://www.landesign.com.au
      • F Offline
        firkins
        A random button could either replace the 60 degree button (45+15), or add another row with a random button and an input box for rotation.
        Just an idea. πŸ’š
        Michael
        %(#000080)["Those who would give up Essential Liberty
        to purchase a little Temporary Safety,
        deserve neither Liberty not Safety."]
        Ben Franklin
          rhankc
          Jim,
          I got your script running, thanks for putting this together. Very Nice!
          Hank
            Gidon Yuval
            Hi y'all,
            I'm not sure I understand what this script does that move/copy doesn't.
            If you don't know where you're going, you're never going to get there.
              rhankc
              It moves your items a key-in distance in an arrow direction. You dont have to set up a construction line or infer and watch the VCB. Key the distance, click a direction and done, Easy.
              Hank
                Gidon Yuval
                But if I select an object then move it along a given axis and type in a distance I get the same result. I'm trying to understand the advantage of activating a script to do this.
                  Stu
                  Gidon,
                  If we are talking about one component, floating in mid air, well away from anything else...your right.
                  But if it's a complex model, with lots of groups/components all nested together its often impossible to find an axis to move along and if you do, your component will instantly snap to the nearest line, component, group etc.
                  This is where Mover becomes REALLY useful! Add to that 45 degree movement, multiple, on axis, rotation options and all controlled by an elegant little window.
                  I rate it as my most useful [and most used] ruby.
                  πŸ˜‰
                  Stu
                    Maggy
                    would it be hard to create a multiple copy option?
                    One tree times 10 times 10 would create a very nice forest, shift some individual trees for a nice natural random effect.
                    I know that there are already several ways in SU or with existing rubies to do this, but it would make this tool even more flexible.
                    [Maggy]
                      Gidon Yuval
                      Stu, I downloaded the script, tried it out and it is indeed a lovely tool. I have one or two questions.
                      Firstly, all the movements are in the opposite direction to the arows. In other words, I'll key in a distance, hit the arrow pointing right, and the object moves left.(?!?)
                      Secondly, I cant figure out how to enter a rotation value. When I hit the "?" button it just rotates any which way it chooses.
                      What have I missed?
                      Oh! And of-course: a big THANK YOU to Jim 😳
                        Stu
                        Gidon,
                        The movement is along the red, green, blue axial lines rather than to the left or right so it's possible to be in a position where it looks as if the movement is in the opposite direction to that indicated.
                        With the rotation.....the options are the indicated degrees or the ? which indicates a random rotation within 360 degrees.
                        And as well as all the discussed functions there is also the copy, return to the 0 axis point and drop to the red/green plane options.
                        All in one little Ruby ❗ ❗
                        Fantastic Jim ❗ πŸ˜†
                        Stu
                          Gidon Yuval
                          Gidon,
                          Stu
                          OK, got it.
                            Jim
                            Maggy,
                            I like the idea of a copy quantity. I think I can fit a little text box in there. Anyone else want to comment?
                              Stu
                              Jim,
                              A multiple copy option would be great ❗
                              And thanks once again.....it's pretty obvious I like this one.
                              πŸ˜‰
                              Stu
                                Jim
                                Mover has a feature where it will move an object by an amount determined by the objects size if the DIST amount is zero or blank. It works since the plugin only supports moving one thing at a time. If I wanted to move multiple selected objects, this feature becomes less useful (if it was useful to begin with.)
                                I wanted to know of anyone uses this feature, and if anyone would be unhappy if I removed it in favor of adding the ability to move multiple selected objects?
                                  Gidon Yuval
                                  Jim, I know I was less than enthusiastic when I first saw the 'mover' but I have since come to use and appreciate it more and more. So first of all: Thank you. Secondly, regarding the above mentioned feature I find that to be very very helpful.
                                  Thanks again.
                                  • Jean-FrancoJ Offline
                                    Jean-Franco
                                    Jim, I just tried your tool and I like it. Thanks a lot. I would prefer to use multiple selection of groups and components. More convenient for me.
                                    Jean-Franco
                                      samtsham
                                      Hi.
                                      Thank you for posting this great ruby.
                                      I'm on a Mac, and I'd like to report some interface-niggles: First of all, the window-size appears to be off. Attached find the window as displayed, when the script is opened. When I resize it, in order to see the rotate-buttons, the horizontal size gets fixed at far too broad, see attachment two, and can't be reduced.
                                      As the window is so big, I can't put it to the side of the model-space, so I have to put it somewhere on top. As soon as I click anywhere in the model window, though, it gets the focus and covers the mover-window, which unfortunately doesn't float, at least not on a Mac.
                                      Third, any effect of the movement only becomes visible, if I click in the model window after I used mover. If I just click the buttons, nothing seems to happen. So visual feedback is rather muddled, I have to know exactly what I want to do, and only get confirmation, after I revert focus back to the model window.
                                      I don't know, if these issues are Mac-only, but I have a feeling, someone else would have already pointed them out, if they weren't.
                                      Thanks for sharing.
                                      SAM from Vienna.
                                      [samtsham]
                                        Jim
                                        I was aware of some of those issues, but not all of them - thanks for bringing them up.
                                        Unfortunately, I do not own or have access to a Mac, which makes it difficult to create a cross-platform version - or even a separate Mac version. My understanding is that they are all Mac specific issues.
                                        Thanks for the comments and interest.
                                          kdjanz
                                          Jim
                                          Could you test it using Safari for Windows as the browser for the HTML? Would that give you a more accurate preview of what the Mac might be seeing?
                                          Just asking a question out my deep Ruby ignorance.
                                          Kelly
                                            Jim
                                            Kelly,
                                            Safari may help remove some of the issues.
                                            Last time I tried Safari (about a month ago,) it wouldn't run on my computer. I'm the guy still running Windows 2000 Pro on an AMD Athlon 1800 with 256 MB RAM. It barely meets the minimum requirements of the latest softwares. I'll try it again.
                                            EDIT:
                                            On second thought, it wouldn't help. You can't tell SketchUp to use one browser over another. I think it always uses Internet Explorer for WebDialogs. Unless someone knows something I don't...
                                            @kdjanz said:
                                            Jim
                                            Kelly
                                            • 1 / 3
