    [Plugin] Skin.rb
    237 Posts 66 Posters 205.7k Views 66 Watching
    • GaieusG
      @bellwells said:
      ...Gaieus' suggestion of removing (placing a # in front of) the 2 lines in the script which calls the 2 UI message boxes is VERY helpful. For others, those 2 lines start with UI "fakestart" and UI "!" They are probably 2/3 the way down the code. Disabling these allows the script to create the faces immediately.
      See, Ron, that's all I know of scripting; "removing lines" - i.e. "destruction" πŸ˜„
      Well, as the school schedule settled in for me, it did so for my friends and family. I also started playing tennis. I have spent practically no time at all on the script since the last post. Sad, isn't it, but please be patient as there is very little work left to be done.
      Just take your time, Darrel! These things are way more important than a bunch of whining, old fart like us who can actually wait...
      πŸ˜„
        architectboy
        So, I finally got enough time to work on the script! And put out another version! πŸ˜„ I am calling this version 2.0 because of just how much has internally changed. There are still bugs, there will be for a while and I have a few (4-6) features that I will put on. The final version at which I will discontinue work on the script will be called Version 3.0
        skin.zip
          SchreiberBike
          I've got just the project to use this on. I'll try 2.0.
          For those playing "a fun little game". πŸ€“ INSIDE JOKE ALERT Granted, but it crashed my computer and everyone else's and now your effort to help us has resulted in great pain. πŸ˜‰ NOT REALLY
            AcesHigh
            can you post another of that TEST IMAGE with the several shapes, so we can see what changed in version 2.0?
            [AcesHigh]
            • EdsonE
              Edson
              good call, aces.
              that image (skin test) is very intriguing as it suggests that the script did less complex things as it evolved in time.
              http://www.mahfuz.arq.br
                architectboy
                While this may not seem like very much improvement, from my perspective is is now Way easier to add functionality to it (because of the code structure). Progress will be relatively quick from now on.
                  architectboy
                  Yay! another version. Version 2.1 can be told to fix it's own mes ups, meaning that the second test specimen below now works "all" of the time. Since the icons are not changing at all, this is the last time in a while that I will upload a zip file. For further versions I will only upload the .rb file.
                  skin.rb
                  skin.zip
                  • FletchF
                    Fletch
                    I love how it says at the top of this forum "Do not discuss scripts in this forum" and everyone proceeds to discuss the scipt... even the mods. πŸ˜„
                    So, I will continue.
                    Thanks for this script. I did the circle on top, box on the bottom test, and the Line on top, arc on the bottom test. Here's my suggestion. The script should figure out the lowest poly lines chosen and divide them to equal the same number of segments as the highest-poly lines. Then it should stitch them, working it's way along to make triangles between each consecutive nearest segment to one another. But that's just my opinion.
                    Fletch
                      architectboy
                      The reason that I don't do that, although it would be Way easier, is that when you're doing complicated shapes it does not produce favorable results. But now that you've mentioned it, I have made up my mind that if someone shows me a tutorial on how to make settings for scripts I will add that as an option.
                        RegH
                        @fletch said:
                        I love how it says at the top of this forum "Do not discuss scripts in this forum" and everyone proceeds to discuss the scipt... even the mods. πŸ˜†
                        Ya got me curious (sorry about OT roaming)..
                        I don't see the text you refer to (at top of this page? of page one?) ?? ❓
                        [RegH]
                          architectboy
                          Are you talking about this?
                          If you are, the explanation is that I have my settings so that most recent posts are on the top, just mentally replace the word "below" with "above", sorry.
                          • FletchF
                            Fletch
                            I was refering to the sticky at the top of the forum for "ruby scripts depository"
                            Fletch
                              RegH
                              Thanks Fletch, I hope I didn't derail the thread, just felt kind of confused 😳
                              [RegH]
                                architectboy
                                I decided to do some research and found that settings are very easy to put into a script. So I am now adding Fletch's idea to the script.
                                  architectboy
                                  So, while I am working out the bugs I made with Fletchs idea, I would like to know what to work on next. If I missed any or you come up with more, please tell me.
                                  Here's an explanation of the upcoming features:
                                  Numerous Sides = The ability to connect multiple sides at once, see pic.
                                  Complex Shapes = Doing shapes that are made up of more than just one face or line section.(I have no idea how to do this)
                                  Auto Smoothing = It automatically smooths the faces coming from any curves.
                                    architectboy
                                    So fletches idea works marvelously! Here's version 2.2 all working. Check out the options dialog if you would, it will soon have a button for it in the toolbar.
                                    Looking at the poll results, I think I'm going to be working on complex shapes for the next version.
                                    skin.rb
                                      Daniel S
                                      This new version is working fantastic!
                                      Thank you!!
                                      Daniel S
                                      • EdsonE
                                        Edson
                                        i am probably asking too much, but would you consider doing a sort of guide to skin.rb so that everyone could understand what the script can do and how to do it?
                                        although it means more work for you, it would allow many people to take full advantage of your fine creation.
                                        thanks anyway.
                                          architectboy
                                          Now if anyone understands what the options do and can come up with better wording for them, please tell me
                                          Skin Tut.skp
                                            SchreiberBike
                                            This is great. Having followed the tut and downloaded version 2.2 I can get some really useful work out of this.
                                            Thank you.
                                            I love the idea that 3.0 will be perfect. Every bit of code I've written was always going to be perfect in the next major release too. πŸ˜›
                                            • 11
                                            • 12
                                            • 4 / 12
