    [Plugin] Skin.rb
    237 Posts 66 Posters 159.4k Views 66 Watching
      Masta Squidge
      Hi, I just came in to say thanks for the nice script, and thus far I'm able to work it with very few errors.
      But I was wondering will you be including an option to auto-smooth the lines as they are made? I know its rather early in the life of your script, but that would be a helpful addition.
      Thanks again for the script, its a time saver and works alot better than the from contours tool in alot of cases.
        architectboy
        It will be considered when I come to that point. Thanks for the idea πŸ˜„
        • Didier BurD Offline
          Didier Bur
          Hi ArchitectBoy,
          Maybe you could have a look at the new versions of extrude_lines.rb or at extrudelinetool.rb. They "auto-soft" extruded edges when original edges are parts of curves, arcs, circles.
          Hope this helps,
          DB
            architectboy
            So life is now settling into the school pattern and I am now getting more time to work on the script. Now it just crossed my mind to check out all the versions that I have put out to you guys to see just how much the script had progressed through time. The results are sad, thus giving me a lot of reason to stop being lazy with the script. I almost feel like apologizing, but I know that you nice people wont accept one. If your wondering what I mean, just take a look at these test results. The unconnected ones came up with an error, the version numbers are on the side and the last row is to show what they were tested on.
              I am actually using 1.9 - to my (more or less) best satisfaction so far...
              πŸ˜„
              Thanks for your efforts, Darrel!
                bellwells
                I think this script works well. I haven't tried it on complicated shapes, though.
                Gaieus' suggestion of removing (placing a # in front of) the 2 lines in the script which calls the 2 UI message boxes is VERY helpful. For others, those 2 lines start with UI "fakestart" and UI "!" They are probably 2/3 the way down the code. Disabling these allows the script to create the faces immediately.
                Ron
                  architectboy
                  Well, as the school schedule settled in for me, it did so for my friends and family. I also started playing tennis. I have spent practically no time at all on the script since the last post.😞 , Sad isn't it, but please be patient as there is very little work left to be done πŸ˜„.
                  Man, does that code look different than last version!
                    @bellwells said:
                    ...Gaieus' suggestion of removing (placing a # in front of) the 2 lines in the script which calls the 2 UI message boxes is VERY helpful. For others, those 2 lines start with UI "fakestart" and UI "!" They are probably 2/3 the way down the code. Disabling these allows the script to create the faces immediately.
                    See, Ron, that's all I know of scripting; "removing lines" - i.e. "destruction" πŸ˜„
                    Well, as the school schedule settled in for me, it did so for my friends and family. I also started playing tennis. I have spent practically no time at all on the script since the last post. Sad, isn't it, but please be patient as there is very little work left to be done.
                    Just take your time, Darrel! These things are way more important than a bunch of whining, old fart like us who can actually wait...
                    πŸ˜„
                      architectboy
                      So, I finally got enough time to work on the script! And put out another version! πŸ˜„ I am calling this version 2.0 because of just how much has internally changed. There are still bugs, there will be for a while and I have a few (4-6) features that I will put on. The final version at which I will discontinue work on the script will be called Version 3.0
                      skin.zip
                        SchreiberBike
                        I've got just the project to use this on. I'll try 2.0.
                        For those playing "a fun little game". πŸ€“ INSIDE JOKE ALERT Granted, but it crashed my computer and everyone else's and now your effort to help us has resulted in great pain. πŸ˜‰ NOT REALLY
                          AcesHigh
                          can you post another of that TEST IMAGE with the several shapes, so we can see what changed in version 2.0?
                          [AcesHigh]
                          • EdsonE Offline
                            Edson
                            good call, aces.
                            that image (skin test) is very intriguing as it suggests that the script did less complex things as it evolved in time.
                            http://www.mahfuz.arq.br
                              architectboy
                              While this may not seem like very much improvement, from my perspective is is now Way easier to add functionality to it (because of the code structure). Progress will be relatively quick from now on.
                                architectboy
                                Yay! another version. Version 2.1 can be told to fix it's own mes ups, meaning that the second test specimen below now works "all" of the time. Since the icons are not changing at all, this is the last time in a while that I will upload a zip file. For further versions I will only upload the .rb file.
                                skin.rb
                                skin.zip
                                • F Offline
                                  Fletch
                                  I love how it says at the top of this forum "Do not discuss scripts in this forum" and everyone proceeds to discuss the scipt... even the mods. πŸ˜„
                                  So, I will continue.
                                  Thanks for this script. I did the circle on top, box on the bottom test, and the Line on top, arc on the bottom test. Here's my suggestion. The script should figure out the lowest poly lines chosen and divide them to equal the same number of segments as the highest-poly lines. Then it should stitch them, working it's way along to make triangles between each consecutive nearest segment to one another. But that's just my opinion.
                                  Fletch
                                  Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                    architectboy
                                    The reason that I don't do that, although it would be Way easier, is that when you're doing complicated shapes it does not produce favorable results. But now that you've mentioned it, I have made up my mind that if someone shows me a tutorial on how to make settings for scripts I will add that as an option.
                                      RegH
                                      @fletch said:
                                      I love how it says at the top of this forum "Do not discuss scripts in this forum" and everyone proceeds to discuss the scipt... even the mods. πŸ˜†
                                      Ya got me curious (sorry about OT roaming)..
                                      I don't see the text you refer to (at top of this page? of page one?) ?? ❓
                                      [RegH]
                                        architectboy
                                        Are you talking about this?
                                        If you are, the explanation is that I have my settings so that most recent posts are on the top, just mentally replace the word "below" with "above", sorry.
                                        • F Offline
                                          Fletch
                                          I was refering to the sticky at the top of the forum for "ruby scripts depository"
                                          Fletch
                                            RegH
                                            Thanks Fletch, I hope I didn't derail the thread, just felt kind of confused 😳
                                            [RegH]
                                            • 11
                                            • 12
                                            • 10 / 12
