    โŒ› Sale Ending | 30% Off Profile Builder 4 ends 30th September
    [Plugin] Ruby Toolbar
    41 Posts 15 Posters 33.9k Views 15 Watching
      Jim
      Ruby Toolbar
      About
      Ruby Toolbar provides some controls over SketchUp's Ruby Panel (or Console.) It is most useful to people who are writing Ruby plugins.
      This is a Windows-only plugin.
      The 5 toolbar buttons are shown below.
      https://sites.google.com/site/jimfoltz/sketchup/my-sketchup-plugins/ruby-toolbar/0936.png?attredirects=0
      They are:
      [ Show/Hide Ruby Console | Clear Console | Load a .rb | Reload last .rb | Browse Plugins Folder ]
      If someone wanted to contribute some good, meaningful icons I'd be grateful.
      The position and size of the console is saved to the Windows Registry when the console is hidden using the toolbar, and restored between sessions.
      Requirements
      • Sketchup
      • Windows
      • Win32API.so (if not already installed.)
      Installation
      Download the .zip file, extact the files, and move them into your Plugins directory.
      Didier, this is actually an update of the RubyPanelToolbar you have archived on your site.
      Download and info here
      • Didier BurD Offline
        Didier Bur
        Cool ๐Ÿ˜†
        very VERY VERY useful tool,
        Thanks a lot from all the developers !
        hem hem ๐Ÿ˜ฎ ๐Ÿ˜ณ where's the gem ? (didn't find it at Sketchy Endeavors ๐Ÿ˜  )
        DB
          tomasz
          Jim,
          Am I blind already? Description of your tool is so interesting ... but where is the link ๐Ÿ˜†
          Thanks a lot!
          Tomasz
          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
            Jim
            Oops, that was a major omission. I've added the attachment to the original post.
            • N Offline
              not registered yet
              When I extracted your .zip file, KI restarted SketchUp and I`can't find it!!! Will you please Bugfix it?
              [Invader ZIM]
              • jujuJ Offline
                juju
                ZIM - some toolbars need to be activated under the "view" menu. Have a look to see if this is the case.
                  Didier Bur
                  Jim,
                  I'm having the "blank icons syndrom" (all png's are in Plugins folder)
                  The line that seems to cause the problem is:
                  imgdir = File.join(File.dirname(FILE), File.basename(FILE, ".rb"))
                  It returns: ./(eval)
                  then the icon file location File.join(imgdir, "rubypanel.png") returns: ./(eval)/rubypanel.png
                  Please help !
                  The 'toggle' method doesn't work also. ๐Ÿ˜  At least in V5.
                  Question: Is findWindow.call(0,"Ruby Console") rely on language settings of SU ? I mean is "Ruby Console" available just for english versions of SU ? In this case the win32api call will not work with other platforms.
                  P.S.:
                  UI.openURL("c;\\program files\\google\\google sketchup 6\\plugins")
                  A non hard-coded command would be handy. Why not get this path from the registry ? Or something like:
                  su_ver = Sketchup.version.split(".")[0].to_i
                  if su_ver < 6
                  devdir = File.dirname(Sketchup.find_support_file("sketchup.exe")) + "\Plugins"
                  else
                  devdir = ...
                  This makes the command compatible for SU5 and 6 (I guess), no matter where the user has installed SU.
                  Regards,
                  DB
                    Jim
                    @didier bur said:
                    Jim,
                    Please help !
                    Didier, I'm, not sure why it works on my computer but not yours. I have updated the script to use a method that will hopefully be more robust. There should be a rubytoolbar folder in which the images are located.
                    This could very well be the case. If you have Ruby installed, you could try your local verion of Win32API.so located in C:\ruby\lib\ruby\1.8\i386-mswin32\Win32API.so.
                    What is the title text of your Ruby Console window? Is it English "Ruby Console", or maybe French? I think findWindow is using the name of the window.
                    @didier bur said:
                    P.S.:
                    if su_ver < 6
                    else
                    devdir = ...
                    I use the find_support_file method; good idea.
                    Thank you for the report, and your patience. Please download and try the updates.
                      Didier Bur
                      Hi Jim,
                      Thanks for the update: icons are there now ๐Ÿ˜„
                      Show/Hide console doesn't work ๐Ÿ˜• (not very important)
                      Clear console only moves the text in the console 1 line up 8O
                      The title of the Ruby console window in french is "Console Ruby". This could cause the problem...
                      But the most important command "Reload script" works OK since the first version ๐Ÿ˜›
                      Thanks again for this very useful tool,
                      Regards,
                      DB
                        @didier bur said:
                        ...The title of the Ruby console window in french is "Console Ruby". This could cause the problem...
                        Thank God I don't need to deal with a "native" version of SU! ๐Ÿ˜„
                          Didier Bur
                          Everything's OK with the french version now, including toggle
                          Only minor tweaks were necessary ๐Ÿ˜†
                          DB
                            Jim
                            Great! But would you mind sharing the minor tweaks so maybe I can make the toolbar more international?
                              Didier Bur
                              Hi Jim,
                              I'm afraid it would be useless because I simply replaced all the calls to "Ruby Console" by "Console Ruby", but that's only for french. Each version of SU does have a particular name for the Ruby Console, so... Even a call to langhandler.rb (with 'getstring') will not work since this deals with a window name, not a message string or such. ๐Ÿ˜ž
                              Regards,
                              DB
                                Jim
                                @didier bur said:
                                Hi Jim,
                                Regards,
                                Didier, GetString would work, but since it's only one string, I won't use LangHandler. I've updated the plugin to support FR.
                                  CPhillips
                                  Hi Jim,
                                  I love this toolbar. I use it constantly.
                                  Feature request: How about saving the state and position of the console in the registry? So if I close and reopen Sketchup it remembers if the console was open and where it was.
                                  Also If you want I could give you the code to read the console log window. Saving is the only use I can think of. But maybe it could be parsed to some effect.
                                    Jim
                                    Thanks Chris,
                                    The version I posted on SketchyUtils isn't up-to-date, I'll remove it. Download the version available in this thread.
                                    The position and size are saved in the registry, but only if the console is closed using the toolbar. Is it possible to save these settings if the console is closed using the X widget?
                                      CPhillips
                                      Ah, much better. Yeah I was still using the old one.
                                      I didn't even know this subsection of the forums was here until yesterday.
                                      As far as detecting the window close message. It wouldn't be easy. One thing you could do is just check the position of the window ever 10 sec or so and see if it has moved/closed.
                                      Regards
                                        Why put the "ruby console" and not the "Web Console" of Jim Foltz?
                                        Seems it is more easy using? ๐Ÿ˜„
                                        (but I am totally new beginner in Ruby script ๐Ÿ’š
                                        PS With the Webconsole seems you can't save (bug ?) ๐Ÿ˜ฎ
                                          BTM
                                          You can save, it just doesn't say that you have the same file open after that. it's weird.
                                            Jim
                                            Maybe I should combine the 2 plugins into 1?
                                            • 1 / 3
