    Depth Maps from SU
    47 Posts 14 Posters 22.9k Views 14 Watching
      Jackson
      Lewis,
      That is one of the best example of lateral SU thinking I've seen! Using fog to create depths maps- you genius!
      Yes, can you post the style/shadow settings you used for these please? I was overjoyed when I realised I could use PS's lens blur filter to post-process Vue's renders- it's own focal length blurring is extremely time-hungry and more importantly absolutely CR*P. I'd love to try the same with SU renders.
      You've made my day,
      Jackson
      Jackson
      • L
        lewiswadsworth
        I'll post both the settings and a tutorial as soon as I can, Jackson. I'm a little crippled here working with a computer that has no real bitmap editor. I just demanded that the IT people buy me a copy of Photoshop CS3 XT for my work computer (one of my job titles here is Technology Adviser, so I should have the technology I need, don't you think?)
        poster-Lewis Wadsworth
        col sporcar si trova
        • KrisidiousK
          Krisidious
          CS3 has a working demo... temp fix...
          By: Kristoff Rand
          • L
            lewiswadsworth
            I actually had to ask a principal to order them to install SketchUp 6 on my computer, so I try not to push my luck...don't worry, I'll get something done soon...I have my own license to PS CS3 XT on my home computer.
            • L
              lewiswadsworth
              Jackson,
              I think this should do it for settings...you can play with the fog (a black fog!) Distance cutin/cutoff to tweak the depth impact. Notice the shadow settings: shadows are NOT on, date and time are inconsequential, it's the sliders that matter...essentially they completely flatten shading. Otherwise this is pretty simple.
              I'll get a full tutorial written tonight.
              --Lewis
              depth.style
                Jackson
                Aw, Lewis you beat me to it. I worked them out for myself using fog, no shadows, edges not displayed and hidden line render.
                This is a PS CS2 lens blurred SU image I just did- very happy with the results!
                Many many thanks for this brilliant tip,
                Jackson
                p.s. expect to see a LOT of lens blurred SU renders from now on ๐Ÿ˜„
                Jackson
                • L
                  lewiswadsworth
                  Glad to help...I wrote something about this in the old SketchUp forums, and no one except jenujacob seemed interested, or else (I assumed) they had already figured it out.
                  --Lewis
                    Jackson
                    Lewis,
                    I definitely missed that one or I would've been all over it. Unfortunately I suppose not that many have PhotoShop CS so that's why it may not have widespread appeal.
                    Jackson
                    Jackson
                    • L
                      lewiswadsworth
                      It should work with any version of Photoshop that has a Channels palette...which would be all of them. I think it might work on the GIMP and related software like Cinepaint, as well, since I believe there is multi-channel support there too. But I don't think the watered-down Photoshop copies, like Photodeluxe and so forth, can use it.
                        Jackson
                        Sorry, I just meant with regard to PS CS' depth of field lens blur filter.
                        Jackson
                        Jackson
                        • L
                          lewiswadsworth
                          I'm sort of old school Photoshop...Gausian Blur forever! But I also use this depth mask with adjustment layers, principally Hue/Saturation and Levels, to create the kind of "atmospheric perspective" fading effect that I used to do with watercolors or tempera, in the old analog days of painting.
                          • K
                            kdjanz
                            Isn't the EPIX format for Piranesi basically a depth map export too? Haven't tried it myself, but I thought that one of the files exported looked similar to what you have achieved.
                            Kelly
                            poster-kdjanz
                            • L
                              lewiswadsworth
                              Kelly
                              I think you are correct...the EPIX format includes a z-pixel which indicates depth. Photoshop is much more common than Piranesi, though, so this hopefully will help people with PS licenses achieve depth-based manipulations with 2D exports from SU6. The third party renderers and modelers that I have used...Max, VRay, and Blender...will happily generate a true depth map, though, that can be used in conjunction with photorealistic renders from those packages.
                              • L
                                lewiswadsworth
                                I was writing up a tutorial on this, as Kris requested, and I noticed (in the file I made to demonstrate this effect) a kind of bug I hadn't seen in previous renderings using this techique.
                                Look at the original image here, direct 2D export (originally a TIFF) from SU6:
                                Now look at this screenshot of the depth mask mode:
                                This is what the depth mask looks like when exported-2D:
                                Obviously the terrain that the chair is sitting on is not showing the proper "depth" shading: it should start out white at the chair, and then shade to grey as it approaches the ramp that the car is sitting on. But it starts a darker grey than the ramp, and stays that way.
                                It doesn't really impact the final result, where I used the lens blur filter in Photoshop and the depth mask as the target:
                                except that the foreground chair shadow and the terrain textures are seemingly blurred more than they reasonably should be.
                                Jackson (or anyone else trying this), while you're playing with this technique, could you keep track of where this kind of error in 2D export occurs? Please let me know. I have several other models where this does not occur, and the depth mask exports to bitmap exactly as it appears on screen.
                                --Lewis
                                • L
                                  lewiswadsworth
                                  I've figured out that if you really want to see how a fog-derived Depth Mask is really going to Export 2D, turn off hardware acceleration under Preferences. Big planes orientated near the horizontal seem to be subject to some odd streaking and abrupt shading changes that do not effect vertical surfaces. It's nothing that couldn't be corrected in Photoshop, but it does make this a little less acceptable a substitute for true Depth Map support in SketchUp. Oh well. Should I still write up a tutorial?
                                  http://www.sketchucation.com/scf/download.php?id=1501
                                  • KrisidiousK
                                    Krisidious
                                    yes by all means because I am just barely following you...
                                    but as I see it... your target has the car included and that's throwing off the map... is the car actually inside your target mask?
                                    By: Kristoff Rand
                                    • K
                                      kdjanz
                                      I did do an export to EPIX and then changed the extension of the file to TIF. On the Mac, the file opened in Preview to show that there were 3 images inside. The first was the visible scene as in SU, the second was the grayscale depth map and the third was pure white - don't know what that was about. But I could then export the second image for my own use without ever going near Piranesi.
                                      Just thought that might be useful to you.
                                      Kelly
                                      poster-kdjanz
                                      • G
                                        gata
                                        Photoshop Elements has a plugin that enables many Photoshop features, like Channels http://hiddenelements.com/
                                        poster-gata
                                        • L
                                          lewiswadsworth
                                          Kelly
                                          EPix is supposed to be an extension to TIFF with two additional channels. I can force it to open in Photoshop, but all I find are the normal 3 RGB channels, unfortunately. What is Preview? I assume it is a Mac only program.
                                          --Lewis
                                          • L
                                            lewiswadsworth
                                            I actually have a license to Piranesi 3 for PC. I just happen to really dislike that application, enough that I never bothered to upgrade to more recent versions. But it is possible to export the depth mask only from Piranesi as a TIF or some other format. It needs to be adjusted slightly, because Piranesi makes nearer objects darker as opposed to lighter, and background in SU becomes some strange blood-red color in Piranesi's depth mask that needs to be selected and filled with white in Photoshop before it will work properly with anything in Photoshop.
                                            Here is the adjusted Piranesi-generated mask:
                                            and here it is applied in Photoshop using the lens blur filter:
                                            There are actually some buggy bits in the Piranesi depth mask as well...striations along the ground plane, and fringing of some kind along the roofline of the background building. Plus, of course, SketchUp's Epix exporter doesn't allow for antialiasing, which means that the depth mask produced from Piranesi has the same prevalent jaggies as the RGB image contained int the Epix file. In other words, with the exception of the problem with horizontal planes a depth mask produced using SketchUp's Fog, Styles, and Shadow controls is somewhat higher quality than one produced using Epix export from SketchUp via Piranesi.
                                            EDIT: I discovered that if you switch Piranesi's View menu > Depth and thenexport a "depth" EPix channel as some normal bitmap (like a TIF)--as opposed to doing that while View > RGB--you end up with a higher quality depth mask that merely needs to be inverted in PS to work properly with Lens Blur and similar techniques in Photoshop. You can combine that Piranesi-generated depth mask with a straight-from-SU6 2D export at the same resolution (and with antialiasing turned on) to get a nearly ideal depth mask situation.
                                            EDIT2: Okay, is anyone reading this and getting quite the same headache I am getting writing it? I think I'm going to call it a day and do something NOT involving depth masks and SketchUp for a while. I'll write up that tutorial tomorrow night.
                                            • 1 / 3
