    SketchyPhysics Alpha
    90 Posts 26 Posters 27.1k Views 26 Watching
    • KrisidiousK Offline
      Krisidious
      I found the controls pretty good, I got how to move stuff and throw stuff, and drop it. and I liked the bars...
      By: Kristoff Rand
      • W Offline
        Whaat
        I like this script so much, I thought I'd do a tribute...Indigo style!
        http://www.sketchucation.com/forums/scf/sas/Ruby/im1184173089.jpg
        Whaat
          CPhillips
          404 Not Found
          (www.sketchucation.com)
          Whaat
          That looks really cool! It will be nice when we can finally do physics and ray tracing in real time. 😄
          • O Offline
            otb designworks
            "sniff, sniff..........feeling sorry for myself............"
            Thanks Chris, you have managed to make the one thing on the planet that makes me regret not having a PC.
            Sure sounds like you guys are having a fun time........... 😞
            Cheers, Chuck
            OTB Designworks is on Youtube
            • N Offline
              namza
              i did that funny work
              you need the last version of sketchyphysics http://code.google.com/p/sketchyphysics/wiki/LatestVersion
              avance3c.skp
                Krisidious
                why not run that Windows Emulator....?
                By: Kristoff Rand
                  CPhillips
                  Very cool. That is the simplest self moving machine I have seen. 😄
                  • N Offline
                    namza
                    i made it afer a lost of test. The problem is that now i CAN'T ( !!) reproduce this machine. It goes with join and groups but all depends of what do i have to join ans what do i have to group ...and in wich order .....
                      CPhillips
                      By the way. I see you made your track out of blocks. That is fine, but you can also just edit the floor. Any staticmesh (like the floor) can be edited at a per face level and will still work.
                      [url=http://www.sketchucation.com/forums/scf/sas/SketchyPhysics/avance3c-track.skp:33txugzx]avance3c-track.skp[/url:33txugzx]
                        CPhillips
                        You can use the joint connection tool to examine the way the joints are connected. In this case each of the 3 cylinders is grouped with a hinge. And the bars are just connected to the hinges.
                        Joint connections can be confusing at first.
                        • N Offline
                          not registered yet
                          Chris,
                          That is nothing short of amazing. I'm awestruck. I'm curious as to why and what it took (in general terms) to create this.
                          Mark
                          P: marsol
                            CPhillips
                            Chris,
                            Mark
                            Thanks Mark.
                            The why is because its fun.😄 I like making things that actually behave the way you'd expect.
                            What it took was a good physics engine (newton) and a lot of work. I have been working on it on and off for over 2 years. Its currently around 10k lines of ruby but I have probably written and discarded 20k.
                            Some of that 10k is code that isn't even enabled yet. SketchyReplay for example records animations and features some non-linear editing. Here is an example. Note the camera behavior and the rewind stuff at the end.
                              architectboy
                              So, I've set up a Sketchy Physics competition for anyone who is interested in modeling with Sketchy Physics.
                                Krisidious
                                is there or could there be, a way to turn on a shader, that would shade or highlight the area in which SketchyPhysics was available with in the model.
                                know what I mean? there is an area in which the Physics work and one where it does not, I'd like to see that area...
                                By: Kristoff Rand
                                  architectboy
                                  Yea, for some reason objects seem to stop moving about 200 feet from the origin.
                                    Krisidious
                                    that's because the Physics are not global... it's just a small area around the axis...
                                    By: Kristoff Rand
                                    • N Offline
                                      not registered yet
                                      Very cool plug in!
                                      If I move the sketchyphysics tool window any other toolbars that are open on my second monitor close.
                                      P: SABBA
                                        CPhillips
                                        You can adjust the size of the world under Plugins->Physics Settings. Adjust world scale to make it bigger or smaller. Note if you make it too big small things will stop working.
                                          CPhillips
                                          Very cool plug in!
                                          Hm. Thats wierd. Ill look into it.
                                          • N Offline
                                            not registered yet
                                            @cphillips said:
                                            Any other comments or feedback?
                                            Has anyone used the SketchySolids toolbar? I am thinking that it is almost worthy of being a separate plugin.
                                            Where can I download SketchySolids?
                                            P: Invader ZIM
                                            • 2 / 5
