    SketchyPhysics Alpha
    90 Posts 26 Posters 28.8k Views 26 Watching
    • BurkhardB
      Burkhard
      absolutly great plugin, thanks
      Burkhard
      http://www.ia-plus.de
      • C
        CPhillips
        Thanks everyone! Here are a few answers to the questions.
        oh yeah with this ruby you can make a model of our solar system, and then have collisions...
        Yes.
        you can have a car driving down the road...
        Yes. In fact I hooked up joystick support a while back. Ill expose it in a future version.
        a back hoe digging...
        Doubt it. Deforming terrain isnt possible with this plugin.
        now can I export movies of this?
        Not yet. I do have a separate plugin called SketchyReplay that records and plays back animations.
        is there wind and water effects?
        Wind no. Water possible in a future version.
        can I assign weight to an object, like a brick, and a 2x4 and a concrete pad, and then weigh the whole structure?
        The physics engine supports materials. A future version will expose them. I dunno about weighing a structure. It might work.
        • KrisidiousK
          Krisidious
          with the backhoe digging I mean you would seperate the dug out part my grouping... it would be fake but look somewhat real...
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            just thinking about the future of this... if you'd like to know what I would do if I could...
            test my architecture... wind shear, snow loads, live loads, tension stress... that kind of thing...
            I tested something last night with it... I took the bricks in the terrain test file, and shrunk them down to about the size of a small rock... then copied them over an over and over until there were hundreds and hundreds of them in a cluster hanging in the air waiting on me to drop em... I wanted them to fall all at once and seem to be a fluid pour of small objects... but what I got was a few dropping at a time... by OC'd E4300 couldn't handle it...
            well this is very exciting stuff thanks so much for sharing and for building it... I can't wait to learn more...
            By: Kristoff Rand
            • W
              Whaat
              This is absolutely amazing! Thanks for all of your work!
              • C
                CPhillips
                Keep in mind that the physics engine is not designed to be that accurate. Its more of a game physics engine. Maybe you could do a first approximation of stresses and what not. But I think you would need a real engineering software for anything meaningful.
                This plug-in hasn't been optimized yet and lots of objects will go slow. I expect I can at least double the performance on >100 objects without too much effort.
                But the biggest bottle neck is sketchups performance. It was not really designed for moving hundereds of objects dozens of times per second.
                Part of your problem may be that you shrank the objects too much. There is an upper and a lower limit to how big and object can be. Objects that are too small wont move.
                • C
                  CPhillips
                  Any other comments or feedback?
                  Has anyone used the SketchySolids toolbar? I am thinking that it is almost worthy of being a separate plugin.
                  • Mike LuceyM
                    Mike Lucey
                    Hi Chris,
                    I'll have to lock myself into a room for a couple
                    of hours with SketchyPhysics and get back on this
                    one.
                    Mike
                    • H
                      Haggai
                      Well I just want to say as everyone that this is a really amazing script, I have look around the different possibilities, there is alot that we can do and it realy increase the use of Sketchup, increase our ideas and help us more with our needs.
                      I know that this is just the begining, and I also know that it will only get better, i will be waiting for it.
                      I really want to thank you for sharing with everyone.
                      one question I have for now, is there a way to control how to "grab" the objects in a way that we can for example grab a cmu block and put it on an other one with presision. When I tried they seem to be floating in the air as I carry them? I will keep trying.
                      Again thank you very much for all the work.
                      P: Haggai
                        mateo soletic
                        Amazing stuff and great work.
                        After watching the videos
                        the possibilities are endless.
                        Concept Illustrations
                        • C
                          CPhillips
                          By default the object will try to move only horiziontaly. Hold down CTRL to drag up and down.
                          There is a tutorial of sorts here:
                          http://code.google.com/p/sketchyphysics/wiki/Tutorials
                          • H
                            Haggai
                            I am doing this but what i meant is that even when I lift up the object it is hard to control them, they are like hanging on a string and swinging as i move.
                            P: Haggai
                            • C
                              CPhillips
                              Oh, I see. I tried it so the object moved faster and it didnt work very well. The problem is the object flys around the scene too fast. Say you drag a cube from one side of the screen to the other. Depending on how far out you are zoomed the object can be moving hundereds of miles per hour. If it bumped into anything along the way that object would go flying.
                              Ill make it adjustable in a future version and you can try it.
                              And I agree, the controls could be better.
                              • KrisidiousK
                                Krisidious
                                I found the controls pretty good, I got how to move stuff and throw stuff, and drop it. and I liked the bars...
                                By: Kristoff Rand
                                • W
                                  Whaat
                                  I like this script so much, I thought I'd do a tribute...Indigo style!
                                  http://www.sketchucation.com/forums/scf/sas/Ruby/im1184173089.jpg
                                  Whaat
                                  • C
                                    CPhillips
                                    404 Not Found
                                    (www.sketchucation.com)
                                    Whaat
                                    That looks really cool! It will be nice when we can finally do physics and ray tracing in real time. 😄
                                    • O
                                      otb designworks
                                      "sniff, sniff..........feeling sorry for myself............"
                                      Thanks Chris, you have managed to make the one thing on the planet that makes me regret not having a PC.
                                      Sure sounds like you guys are having a fun time........... 😞
                                      Cheers, Chuck
                                      OTB Designworks is on Youtube
                                      • N
                                        namza
                                        i did that funny work
                                        you need the last version of sketchyphysics http://code.google.com/p/sketchyphysics/wiki/LatestVersion
                                        avance3c.skp
                                        • KrisidiousK
                                          Krisidious
                                          why not run that Windows Emulator....?
                                          By: Kristoff Rand
                                          • C
                                            CPhillips
                                            Very cool. That is the simplest self moving machine I have seen. 😄
                                            • 2 / 5
