[Plugin] TextureImporter = Batch images into material textures...
https://sketchucation.com/pluginstore?pln=TextureImporter
A new simple extension which imports all jpg/png files in a selected folder and make new materials in the model named after them, using them as textures. -
@tig is it possible that if the folder contains PBR images that the importer could create mats with normal, roughness etc assigned correctly?
Example:
asphalt-01_basecolor
asphalt-01_normal
asphalt-01_roughness
asphalt-01_metallic
asphalt-01_opacityThis would create asphalt-01 material in SketchUp with the PBR stack correctly linked?
I'll look into it...
Here's v1.1
It has added support for PBR data textures if available/relevant [>=v2025]. It also supports tiff files as well as jpg & png.
Any non-relevant PBR stuff in the folder is ignored.
Full report of processing on completion... -
Here's v1.2
It now simplifies the PBR file material-naming where possible [some authors add suffixes regarding image size etc],
it reverts to previous current material after processing rather than the last imported one,
it skips inappropriate types of image files, sometimes included for use by other apps,
it now has status-bar reporting on its progress [1 of 3 ... etc]
and it now offers the chance to process any image-files in nested subfolders [one level] if desired.
