    Robo Toolbar
    6 Posts 4 Posters 107 Views 4 Watching
    • jujuJ
      juju
      Who's the author of this extension / plugin? The extension / plugin works well for me, well done!
      Apart from extensions that take long to load (because of licensing checks running, or the like) and subsequently isn't loaded in time to be included in created toolbars, it seems to be pretty stable. I've had issues with manually creating custom toolbars (both in SU and LOTT) getting messed up (tools not loading, icons not showing, even tools getting placed in toolbars they were never originally placed in) between reloads / startups, but it needs crucial additional functions - saving and loading.
      Can you include a function to save toolbars (created with the tool) to external files so that the settings can be backed up and loaded again to recreate the toolbar without having to spend time to manually recreate it?
      It will make this tool something to keep in my toolbelt!
      alexpacio2013A 1 Reply Last reply
        @juju that's @alexpacio2013
        1 Reply Last reply 👍
        • alexpacio2013A
          alexpacio2013 @juju
          @juju Hi. I had already created the feature for saving and reimporting toolbars, but then I removed it. I’m making some changes to it now. Of course, if you load the toolbars in another version of SketchUp or on another computer, you’ll also need the icons and plugins they’re linked to; otherwise, they won’t work. In any case, over the past few days I’ve made some further changes, partly thanks to your suggestions. I’ll publish them tomorrow along with the toolbar save/import feature, and then I’ll add the link as well.
          • alexpacio2013A
            alexpacio2013
            I’ve made some changes to make it even more sophisticated, but I’ve had to create two versions because Extension Warehouse’s rules don’t allow some of the features described below. It’s worth noting that I’ve never published anything on Trimble’s website, only on SketchUcation. I’ve published the standard version on SketchUcation, but I’d like to publish the full version too. I’m doing some tests to see what I can do to resolve these issues. If any of you know more about this than I do, please speak up. Thanks.
            Robo Toolbar: differences between the standard and Full versions
            Both versions are the same plugin. The Full version includes two additional features, and those are the reason Extension Warehouse might not accept it.
            What they have in common
            Both versions let you build your own toolbars by dragging and dropping commands, choose custom icons, create key buttons that press a key combination, and add separators. You can rename buttons and export or import toolbar backups, including icons, key buttons, and names. They include Help and section explanations in five languages, and work on both Windows and Mac.
            What the Full version adds
            • It can also detect items in the Extensions menu that some plugins create without a real command behind them. The standard version cannot detect these and displays only actual commands.
            • It includes Ruby Script buttons: buttons that run Ruby code you write.
            • It can also import Ruby scripts from a backup, but only after displaying a warning. An imported script runs only after the user has read its code and clicked “Approve and Run.” The standard version never imports code.
            • The standard version is distributed through Extension Warehouse and SketchUcation; the Full version is available only from the Robo Tools website.
            Why the Full version doesn’t comply with Extension Warehouse’s rules
            1. It changes how SketchUp works. To find Extensions menu items that were created without a command, the Full version hooks into SketchUp’s menu system and modifies it. This changes how SketchUp behaves for all installed extensions, not just Robo Toolbar. Trimble’s rules prohibit modifying Ruby or SketchUp components used by all plugins, because one plugin could cause others to stop working.
            2. It runs code supplied as text. Ruby Script buttons turn text into code and run it with all of SketchUp’s permissions. That code could change the model and read, modify, or delete files. Extension Warehouse’s rules prohibit this kind of code execution (Ruby’s “eval” function), because it is a simple way to run unchecked code, especially if it comes from someone else’s backup.
            jujuJ 1 Reply Last reply
            • jujuJ
              juju @alexpacio2013
              This here, if I understand it correctly, can link to a custom button (with your own defined image?) to extensions (scripts) that can be executed but never received a graphical launch interface. This might actually be quite useful. All the other features are seemingly power user (or programmer level) functions, which I would think most users may not be interested in. This is useful as there are (from memory) some extensions that do not have a "button" and you need to go look for it in the menus somewhere.
              Robo Tools website? I have obviously missed it. Kindly provide a link so people can visit.
              Here's another thought, it comes from how traditional CAD software works. Main (primary) menus and fly-out (secondary) menus. Being able to group/nest certain toolbars under a main tool button, you activate the primary button and the secondary appears and you can select from the functions you grouped under that. The primary toolbar remains on screen and the secondary only appears when the primary is activated, and only gets replaced when another primary button is selected. This will help free up even more screen real estate. Have I missed these type of extensions or do they simply not exist?
              R 1 Reply Last reply
                rv1974 @juju
                @juju do you find it a more solid and stable than LOTT? I so tired of fighting it
