    Medeek Project
    126 Posts 3 Posters 20.9k Views 4 Watching
    • medeekM
      medeek
      Version 1.3.2 - 11.04.2026
      • Enabled blocks within the House Builder.
      • Created a Block Editor and Block Manager for House Builder blocks.
      • Added the following drafting primitives to the House Builder toolbar: Ellipses, Elliptical Arcs, Spline, and Blocks.
      • Added the following modify tools to the House Builder toolbar: Move w/ Base Point, Rotate, and Mirror.
      • Addressed a number UI and performance bugs in both the House Builder and Block Editor.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Tutorial 10 - Block Editor (19.42 min.)
        design.medeek.com
        • medeekM
          medeek
          I have had some requests by users for some sort of AI integration within the plugins. That was actually the reason for my fairly recent addition of the Medeek API a few months ago. However the API alone is only an adapter so that AI can connect (MCP server) to the extensions. I have not yet created an actual AI integrated tool or plugin. I may give this some further consideration however it will be experimental at first.
          I'm not even sure that an AI can realistically understand a floor plan very well and what it means to do proper "space planning". If it can then I will be genuinely surprised but it remains to be seen. If it can't then all of our jobs are safe for while longer.
          design.medeek.com
          • medeekM
            medeek
            I've spent about three days putting together an experimental AI harness for the House Builder it is actually quite interesting to see it run. Even more interesting than actually running this AI tool is actually having spent the time to develop it.
            Ultimately I had to us AI to build the AI harness and the reason behind this is that I don't actually know how an AI reasons or thinks about a problem, or what information it wants or needs. So the best way to design this harness was to ask ChatGPT (GPT 6 Astra) what tools or information would an LLM best understand and work with. After some back and forth and and a few false starts we arrived at a minimal and efficient toolset with which the AI/LLM could manipulate the model inside of the House Builder (Floor Plan only for now). I would call this development project a collaboration, however most of the edge cases were detected by me and then rectified by the AI. It honestly feels like I have an employee now, I will say it does seem a bit strange.
            For something like this to work you have to build a "spatial model" that the AI can understand and fully comprehend, a clear and concise picture of what it is dealing with. In other words it needs to be able to manipulate the model and then instantly get feedback (especially if there are errors or it tries to do something illegal). Also when it does do something illegal you need to explain why it was illegal in very definite terms, otherwise it cannot recover.
            Bottom line is that the harness is paramount to providing a successful connection between the AI engine and the House Builder interface. If this is not created carefully and provides logical and concise data, the AI will be running blind and will makes all kinds of unforced errors. This was even more apparent when I tested weaker models like Luna and Haiku.
            To be able to run this tool you will need to have an API key with at least one provider (OpenAI or Anthropic). Personally I prefer OpenAI's API implementation over Anthropic, but they are close in performance. I also think OpenAI's cost per token is considerably cheaper than Anthropic's right now, so that is something worth taking into consideration.
            My honest assessment at this point: I don't think AI has the experience and reasoning to do really effective architectural space planning. It can follow directions well enough and handle simple structures but I don't think it is yet capable of designing your next "dream home". So for now, we are still safe, but in a year or two I may have to revisit this assessment.
            design.medeek.com
              Could this work with local AI models?
              • medeekM
                medeek
                I've got mdkAI working fairly well. However my own interface can never be as good as the regular chatbot interfaces so I decided to add mdkMCP. Currently I'm testing the MCP integration with Claude. After a bit of coercion I got it to faithfully duplicate a s simple floor plan quite accurately.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.3.3 - 11.12.2026
                  • Enabled the mdkAI tool/inteface for the House Builder.
                  • Enabled the mdkMCP server and status tool for the House Builder.
                  The House Builder MCP Server can be downloaded directly here:
                  https://design.medeek.com/calculator/sketchup/Medeek_House_Builder_0.5.5.mcpb
                  design.medeek.com
                  • medeekM
                    medeek
                    Tutorial 11 - mdkAI & mdkMCP (22:01 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.3.4 - 11.15.2026
                      • Updated the Garage and House Builders to allow for the standard 30 day trial period.
                      design.medeek.com
                      • medeekM
                        medeek
                        It has been a few days now since I've wrapped up most of the major updates to the House Builder and to be perfectly honest I haven't received much feedback on it.
                        However this morning I received an interesting email from a power user who is now using extensively. The fact that him and his colleague are finding such utility with it is very good news and breath of fresh air. I wasn't sure if almost two months of work that I sunk into this "concept" was going to be worth the time and effort.
                        His exact comment was:
                        It's a huge improvement. So much faster to build plans and we are using it for dimensioned floor plans. The print feature is 100x better than Layout on a 3d drawing.
                        He did note however that he wished it had better collaborative capabilities so that he could sync his machine running SketchUp automatically with his partners (House Builder JSON database). I will need to give this some careful consideration over the Thanksgiving break and see what system I can devise that will allow for this type of collaborative workflow.
                        There is always more to do.
                        Additionally I'm experimenting with the idea of including a button in each viewport that allows the user to automatically export that data into a SketchUp Layout file, or a page within a SketchUp Layout file. I am still in the planning stages on this and I'm not even sure that is entirely feasible yet. If it is feasible it probably will only be backward compatible to SU 2026 and not compatible all the way back to SU 2017 like the rest of the extensions are, just an FYI.
                        design.medeek.com
