    [Plugin] THK Laser Tool v2.0 — 3-Axis Live Laser Measure + Multi-Pin Persistent Overlay + 1-Click Dimensions
    2 Posts 2 Posters 22 Views 2 Watching
    • T
      THK Tools Newcomers
      Hi everyone,
      As an architect using SketchUp every day, I was constantly frustrated by standard measuring workflows:
      • The Tape Measure takes too many clicks just to check room width, depth, and ceiling height.
      • Basic cursor-laser tools split numbers at the mouse pointer and disappear the moment you switch to Move or Push/Pull.
      So I built THK Laser Tool v2.0 — a 60 FPS architectural 3-axis (X / Y / Z) laser distance meter with Multi-Pin Persistent Overlay and One-Click Native Dimension Baking.
      Key Features
      • Undivided Full Object-to-Object Spans: Never splits numbers at the cursor. Shows true wall-to-wall and floor-to-ceiling clearance across X, Y, and Z plus live Area (m² / ft²) and Volume (m³ / ft³).
      • Multi-Pin Persistent Overlay (SketchUp 2023+): Left-click to drop up to 20 pins (#1, #2, #3…). Press ESC or switch freely to Select, Move, Push/Pull, or Scale — all pinned dimensions stay visible on screen while you model.
      • One-Click Batch Native Dimensions (B): Convert all dropped pins (or the active live span) into native editable SketchUp Linear Dimensions in a single Ctrl+Z undo step.
      • Glass & Curtain Wall Pass-Through (G): Stop at glazing by default, or pierce up to 16 translucent glass layers to measure the solid structure behind windows and partitions.
      • Rotated Axes, Face Align & 2D Parallel Plans: Automatically tracks custom Drawing Axes, aligns to angled walls (Face Align), and works seamlessly in both Perspective and Parallel Projection (2D Plans / Elevations).
      • Metric, Imperial & Model Auto Units: Model Auto, mm, cm, m, Architectural ft/in (1", 1/8", 1/16"), decimal ft, and decimal in.
      • Anti-Overlap Frosted HUD: Adjustable translucent pill badges with unified 2D collision repulsion.
      Compatibility
      • SketchUp Desktop 2023, 2024, 2025, 2026+
      • Windows & macOS (HiDPI / Retina ready)
      • Officially Trimble-Signed & Encrypted (.rbe)
      Get THK Laser Tool v2.0 (Perpetual License, Free v2.x Updates):
      https://thktools.gumroad.com/l/thk-laser-tool
      Feedback and feature suggestions are very welcome!
      — THK Tools!
      • KrassK
        Krass
        Hello,
        no free trial?
        Krass
