<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Plugin] THK Laser Tool v2.0 — 3-Axis Live Laser Measure + Multi-Pin Persistent Overlay + 1-Click Dimensions]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1795442912540-thk_laser_cover_1280x720.png" alt="thk_laser_cover_1280x720.png" class="img-markdown  img-fluid" width="1280" height="720" /></p>
<p dir="auto">Hi everyone,</p>
<p dir="auto">As an architect using SketchUp every day, I was constantly frustrated by standard measuring workflows:</p>
<ul>
<li>The Tape Measure takes too many clicks just to check room width, depth, and ceiling height.</li>
<li>Basic cursor-laser tools split numbers at the mouse pointer and disappear the moment you switch to Move or Push/Pull.</li>
</ul>
<p dir="auto">So I built THK Laser Tool v2.0 — a 60 FPS architectural 3-axis (X / Y / Z) laser distance meter with Multi-Pin Persistent Overlay and One-Click Native Dimension Baking.</p>
<p dir="auto">Key Features<br />
• Undivided Full Object-to-Object Spans: Never splits numbers at the cursor. Shows true wall-to-wall and floor-to-ceiling clearance across X, Y, and Z plus live Area (m² / ft²) and Volume (m³ / ft³).<br />
• Multi-Pin Persistent Overlay (SketchUp 2023+): Left-click to drop up to 20 pins (#1, #2, #3…). Press ESC or switch freely to Select, Move, Push/Pull, or Scale — all pinned dimensions stay visible on screen while you model.<br />
• One-Click Batch Native Dimensions (B): Convert all dropped pins (or the active live span) into native editable SketchUp Linear Dimensions in a single Ctrl+Z undo step.<br />
• Glass &amp; Curtain Wall Pass-Through (G): Stop at glazing by default, or pierce up to 16 translucent glass layers to measure the solid structure behind windows and partitions.<br />
• Rotated Axes, Face Align &amp; 2D Parallel Plans: Automatically tracks custom Drawing Axes, aligns to angled walls (Face Align), and works seamlessly in both Perspective and Parallel Projection (2D Plans / Elevations).<br />
• Metric, Imperial &amp; Model Auto Units: Model Auto, mm, cm, m, Architectural ft/in (1", 1/8", 1/16"), decimal ft, and decimal in.<br />
• Anti-Overlap Frosted HUD: Adjustable translucent pill badges with unified 2D collision repulsion.</p>
<p dir="auto">Compatibility<br />
• SketchUp Desktop 2023, 2024, 2025, 2026+<br />
• Windows &amp; macOS (HiDPI / Retina ready)<br />
• Officially Trimble-Signed &amp; Encrypted (.rbe)</p>
<p dir="auto">Get THK Laser Tool v2.0 (Perpetual License, Free v2.x Updates):<br />
<a href="https://thktools.gumroad.com/l/thk-laser-tool" target="_blank" rel="noopener noreferrer nofollow ugc">https://thktools.gumroad.com/l/thk-laser-tool</a></p>
<p dir="auto">Feedback and feature suggestions are very welcome!<br />
— THK Tools!</p>
]]></description><link>https://community.sketchucation.com/topic/165139/plugin-thk-laser-tool-v2.0-3-axis-live-laser-measure-multi-pin-persistent-overlay-1-click-dimensions</link><generator>RSS for Node</generator><lastBuildDate>Mon, 23 Nov 2026 17:59:02 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/165139.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 23 Nov 2026 14:08:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Plugin] THK Laser Tool v2.0 — 3-Axis Live Laser Measure + Multi-Pin Persistent Overlay + 1-Click Dimensions on Mon, 23 Nov 2026 15:49:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
no free trial?</p>
]]></description><link>https://community.sketchucation.com/post/1624218</link><guid isPermaLink="true">https://community.sketchucation.com/post/1624218</guid><dc:creator><![CDATA[Krass]]></dc:creator><pubDate>Mon, 23 Nov 2026 15:49:21 GMT</pubDate></item></channel></rss>
