Fredo Topo Shaper Strangeness
I went to use Topo Shaper in SU 2022 and noticed the icons were gone in the Topo Shaper tool tray. Turned it on and off a few times and nothing.
I was using it in SU 2026 fine. So I went ahead and uninstalled it in both 2022 and 2026 and reinstalled it in each and now I can't see anything at all.
Usually if it goes missing I turn it on and off in View: Toolbars but this time I can't see anything.
Help!
Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
If you are running outdated Libfredo it may be the cause. Hard to say when the only clue is 'missing icons'.
@Rich-O-Brien Thanks, Rich.
I got this from DaveR over at Sketchup Community. Everything is back to normal. Was rather weird what happened.
"You can manage the licenses in the Sketchucation tool or go to the Sketchucation site. Click on Plugin Store>My Licenses. Click on the drop down arrow next the 3/3 for TopoShaper and release the license. Then you should be eable to activate the license again in the version of SketchUp you are using. Click on the green License button to download a copy of it if you need it.
After releasing the licenses quit SketchUp and do a cold reboot of your computer. They start SketchUp and see if the toolbar buttons are displayed.?
