    ModLumi : Un SketchUp like comme on les aime!
    146 Posts 6 Posters 14.0k Views 5 Watching
    • PatrickP
      Patrick
      Oui effectivement pas besoin de mettre un roman ! merci pour la réponse.
      • G
        Glenn at home @ntxdave
        @ntxdave said:
        @Glenn-at-home said:
        @ntxdave Highlight some text, right click and select translate selection and then choose entire page 😉
        Thank you sir! Wish there was a way to do that on my iPad.
        Ah, didn't think about on a mobile device. My bad 😞
          ModLumi est aussi disponible pour MAC! 😉
          Hi all,
          Modlumi now runs on the Mac too. You can get it from the download button on modlumi.com , or directly here: modlumi.com/download/latest/macos . It's free.
          It's the same desktop app as on Windows: save models straight to disk, File → Save to Image…, plugins and scripting with the script console and editor, and all the built-in plugins.
          Getting started
          Unzip the download and move Modlumi to your Applications folder.
          The app is signed and notarized by Apple, so it opens without security warnings.
          Shortcuts use Cmd where Windows uses Ctrl, so Cmd+N, Cmd+A and so on.
          What you need
          A Mac with Apple silicon (M1 or newer) running macOS 15 Sequoia or later. Intel Macs aren't supported yet.
          This is the first Mac build, so expect a few rough edges. If something looks or feels off, please use Help → Report a Bug or Send Feedback… or post it here as usual.
            Il faut mémoriser la position de la face avec la flèche basse et non Maj comme dans SKetchUp!
                Rendu Gemini
                Rendu Gemini
                Rendu et fonction Vizcom
                    On me donne cela pour savoir comment enlever le Gizmo Section...
                    J'y réponds ( Clic Droit sur sa sélection / hide) mais que n'importe quelle IA nous efface cela toute seule! 🙂
                    Et je dérape un peu! 🙂 (Flow)
                    Avec son et grand écran!
                    Camera_tracking_out_from_room_3fc08dc1.mp4
                      Push Pull de surface (s) courbe (s)
                        La magie du Copie / Rot / % 🙂
                            alt text
                            alt text
                              Magie de la recopie pivotée! 🙂
                              alt text
                              alt text
                                Du surf dans des conditions extrêmes! 🙂
                                alt text
                                alt text
                                alt text
                                • PatrickP
                                  Patrick
                                  Je regarde à faire mon bazar pour Modlumi mais cela ne va pas être évident... Pour l'instant j'ai perdu mon bouton d'envoi via le copier/coller
                                  • PatrickP
                                    Patrick
                                    Cette première migration est faite avec Gemini, maintenant je regarde avec Claude qui est plus compétent (je trouve) pour le code.
                                    Il me répond :"Le dépôt contient modlumi.d.ts et aucun mot « clipboard » : il n'y a donc très probablement pas d'API de presse-papiers. Je lis la définition réelle de PluginContext."
                                    Il va falloir goupliller !
                                    Ha crotte : "Vous n’avez plus de messages gratuits jusqu’à 13:20."
                                    Patience et longueur de temps...
                                    • pixelcruncherP
                                      Salut Patrick,
                                      Merci pour le retour, et bravo pour Gemini Studio, ça a l'air très prometteur !
                                      Tu as bien vu : aujourd'hui un plugin ne peut pas récupérer l'image de la vue. View.writeImage est réservé aux scripts, et il n'y a pas d'accès au presse-papiers.
                                      Nous allons ajouter dans la prochaine version, qui sort bientôt, une API qui permet à un plugin de faire le rendu de la vue directement en mémoire et d'obtenir l'image en PNG. Avec context.fetch (permission "network"), ton plugin pourra alors envoyer l'image et le prompt directement au service IA, puis afficher le résultat dans ta galerie, sans passer par l'export et le copier/coller. Bref, ton bouton d'envoi sera de retour.
                                      Pour Duck.ai, qui n'a pas d'API, il faudra encore passer par le copier/coller dans un premier temps. Un service avec API, comme Gemini, fonctionnera directement.
                                      Je te préviens dès que la version est disponible. N'hésite pas à nous dire si l'API te convient une fois que tu l'auras essayée.
                                      (Message traduit avec l'aide d'une IA.)
                                      • PatrickP
                                        Patrick
                                        Hello et merci pour ton retour d'info.
                                        j'ai fait ce petit plugin pour ne pas utiliser les services IA via les clés API car cela suppose une facturation qui, même si elle n'est pas onéreuse, reste assujettie à un compte et un moyen de paiement dûment enregistré.
                                        Donc je passe par les IA en ligne qui souvent acceptent un usage avec quota avec un simple mail en guise de création d'un compte utilisateur, duck.ai faisant exception.
                                        Cela suppose de faire les copier/coller à la main ou automatisés avec mon petit bazar.
                                        Donc si ton API permet de gérer les copier coller c'est tout bon pour moi, gérer la connexion via une clé API étant une voie que pour l'instant je laisse de coté.
                                        • PatrickP
                                          Patrick
                                          J'explore le code de modlumi avec Gemini dans mon bazar pour la conception... en attendant le copier coller.
                                          Prompt : peux-tu me faire le code javascript pour modlumi afin réaliser en 3d une plaque de cuisson à 3feux gaz et un électrique, avec les boutons alignés à droite.
                                          Mais il a fallut batailler !
                                          https://share.gemini.google/RGjHi6sk2J5w
                                          • pixelcruncherP
                                            Merci Patrick, très intéressant de voir Gemini à l'œuvre !
                                            Pour le copier-coller : tu as trouvé un vrai bug. Le presse-papiers de Modlumi est limité à 8 Ko, et un script comme celui de la plaque de cuisson (10 à 12 Ko) dépasse cette limite, donc le collage échoue sans prévenir. Je corrige ça pour la prochaine version.
                                            J'ai aussi regardé ta conversation. Gemini a inventé plusieurs noms qui n'existent pas dans l'API de Modlumi, d'où les erreurs successives. Les bons noms :
                                            • face.extrude(distance), pas pushPull
                                            • model.addMaterial(...), pas model.materials.add(...)
                                            • entities.addCircle(centre, rayon, options), qui renvoie directement la face
                                            Tout est déclaré dans modlumi.d.ts (https://modlumi.com/docs/modlumi.d.ts). Si tu donnes ce fichier directement à Gemini, il devrait se tromper beaucoup moins. Je vais aussi améliorer les messages d'erreur pour qu'ils proposent le bon nom.
                                            Thomas
                                            (Message traduit de l'anglais par IA.)
                                            • 7 / 8
