    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    548 Posts 101 Posters 601.0k Views 99 Watching
    • fredo6F
      NEW RELEASE: LordOfTheToolbars v4.1a - 20 Oct 26
      Requirements
      • LibFredo6: v16.3a or above
      LordOfTheToolbars 4.1a is a maintenance release including:
      • Compatibility SU2027
      • Removal of notifications
      • Bug fixing
      Home Page of LordOfTheToolbars for information and Download.
      Main post of this LordOfTheToolbars thread.
      jujuJ 1 Reply Last reply 😊
      • jujuJ
        juju @fredo6
        Requirements
        • Bug fixing
        LordOfTheToolbars 4.1a: Error starting up plugin (creating menus and icons)
        undefined method startup' for F6_LordOfTheToolbars:Module [in Lib6Core.rb6 - #block in effective_load_part2(): line 1140]
        fredo6F 1 Reply Last reply
        • fredo6F
          NEW RELEASE: LordOfTheToolbars v4.2a - 21 Oct 26
          Requirements
          • LibFredo6: v16.3b or above
          LordOfTheToolbars 4.2a is a maintenance release including:
          • fix to the plugin, as v4.1a did not work.
          • Bug fixing
          • fredo6F
            fredo6 @juju
            @juju
            It should be fixed in LOTT v42.a. Sorry for the inconvenience.
            fredo6F 1 Reply Last reply πŸ™
            • fredo6F
              fredo6 @fredo6
              Does this mean it works now?
              • jujuJ
                juju @fredo6
                @fredo6 Thank you for the effort you put into your extensions and maintaining them, it is appreciated.
                The Muzwalls loading error seems to be resolved, that error message no longer pops up. Unfortunately the custom toolbars with the MuzWalls items doesn't work, buttons greyed out while the actual MuzWalls toolbars are fine and functional.
                The toolbar editing problem, where items are not added once the toolbar was checked to appear on screen, still persists. It doesn't update any custom toolbar additions or omissions once the toolbar was selected to appear on screen. The only work-around is to delete the toolbar and recreate it from fresh.
                • LinearGraphsL
                  LinearGraphs
                  Curious, any idea why my pallets would look like this in 2017 make? Out of support thing?
                  • fredo6F
                    fredo6 @LinearGraphs
                    @LinearGraphs
                    Which scale factor do you use on your monitor?
                    What happen if you close the vignette stripe and reopen it (via the menu Tools > Fredo6 Collection > LordOfTheToolbars?
                    • LinearGraphsL
                      LinearGraphs
                      Toggling visibility has no effect. Ive actually reset and all and all my pallets and setting and started from scratch as well. This is a fresh install of the latest version.
                      • fredo6F
                        Did you use 150% before, with the previous version of LibFredo6 and SU2017?
                        It may be a bug I introduced in LibFredo or LOTT, because SU2017 is the only version that does compute size in physical pixels and not in logical pixels.
                        However, on my laptop, SU2017 behaves well, but my scale is 125%
                        • LinearGraphsL
                          LinearGraphs
                          I used to only use external monitors, but now im using the laptop screen. Tried all scale settings, no dice.
                          • fredo6F
                            This is an issue with SU2017, which as far as I remember does not support well external monitors with different resolutions as the main computer screen.
                            Could you go to Window > LibFredo6 Settings... > Default Parameters
                            At the top of the dialog box, check the first line and set the factor to 1.5
                            No guarantee it works, but worth trying.
                            LinearGraphsL 2 Replies Last reply 😿
                            • jujuJ
                              juju @juju
                              @fredo6 Any ideas on this yet?
                              • fredo6F
                                Did you solve the problem of size of the Vignette Stripe?
                                For Muzwalls, I think this is due to the late loading of the plugin. So, LOTT cannot catch them at startup.
                                For custom toolbars, I can check, but I think you have to restart Sketchup to see the changes.
                                • LinearGraphsL
                                  LinearGraphs @fredo6
                                  @fredo6
                                  Unfortunately, no. No dice. Still clipped.
                                  • LinearGraphsL
                                    @fredo6
                                    Is there no way to reset it? Mind you, this is happening on the laptop display with no external monitors connected.
                                    • jujuJ
                                      juju @fredo6
                                      Is there no load delay option that can be done? Or perhaps advise for MuzWalls authors how to get it to load faster and checking of licensing? There are other extensions that also have to load and check licensing that do seem to load fine.
                                      I've tried restarting inbetween, it doesn't make a difference, changes do not reflect once the custom toolbar was actualised (ticked) to show on screen, even if you switch it off and switch it back on later.
                                      • fredo6F
                                        Custom toolbars cannot be updated once on screen. This is because toolbars in Sketchup are not editable. I think LOTT can just add new icons.
                                        Normally, at next restart, the custom toolbars should show as designed.
                                        For Muzwalls, I have to check what is the real issue.
                                        • 24
                                        • 25
                                        • 26
                                        • 27
                                        • 28
                                        • 27 / 28
