    Can't fill the base of my model
    12 Posts 3 Posters 641 Views 3 Watching
      Jianming Mo Newcomers
      It could be that your model units are too large. Tiny geometry like 0.2 will break or disappear easily in SketchUp.
        Try resetting your model scale.
          The model is quite large. You have the palm tree at around 43 KM tall. Modeling with the units set to meters is good for 3D printing but this is probably much larger than it needs to be. That said, there are a lot of "forks" in the bottom edges that create problems for Intersect Faces. I deleted the large face and then started stitching from end point to end point to fill in faces. I did a little cleanup at a few points in order to get faces to form but when I was finished it looked like this.
          I ran CleanUp3 to remove the unneeded edges.
          There'll be some other cleanup such as internal faces and stray edges to remove. Solid Inspector and Solid Inspector2 along with Solid Solver can help with some of that.
          • L
            Leggy
            I know it’s huge , i had to keep scaling it to get the chamfer tool to work , the real thing is 63cm. I’ll download SI2 and SS tonight, and cleanup 3. Did i do something wrong? Can i download your cleanup?, thanks Dave
            Dave RD 1 Reply Last reply
              Dave R @Leggy
              Probably not specifically. What did you start with for your file? How did you make it 3D in the first place?
              Sorry. I didn't save it.
              • L
                Leggy
                I traced over a photo then extruded and chamfered. Could you save the file so I could down load it
                • L
                  Leggy
                  where do I find solid solver , its not in the extension warehouse
                    Are you aware that there are many extensions available right here at Sketchucation?
                    SketchUp Plugins | PluginStore | SketchUcation
                    SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                    (sketchucation.com)
                    Use the Sketchucation Extension Store to find and install it.
                    • L
                      Leggy
                      It’s just hard to keep up 🤣, is there a list of the , i dont know, top 25/50/100 extensions to have. how many do you use?
                      • L
                        Leggy
                        I managed to clean up the palm trees , and they are printing. The problem was tiny , tiny lines i had to zoom in really deep to find it. Solid inspector helps a lot
                        1 Reply Last reply 👍
                          Dave R @Leggy
                          @Leggy
                          I don't have a list that long. Solid Inspector, Solid Inspector2, Solid Solver, Eneroth Solid Tools, Bool Tools2, A bunch of Fredo6's extensions ...
                          It depends a great deal on the modeling project. Sometimes I don't use any extensions.
