    [Plugin] Bounding Box View
    21 Posts 16 Posters 26.7k Views 16 Watching
    • Didier BurD
      Didier Bur
      I also have a plugin called "proxy" on the RLD: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=599 by A. Billyard: "Swaps component definitions with bounding boxes."
      Does this one do the same thing ? Apparently yes.
      DB
        david23lara
        Just AWESOME! thanks!
          alien_killer
          Thanks alot mate... i hope it works with vray.... one reason i moved to Max was cause of proxies.... but SKP is the best
          • ccaponigroC
            ccaponigro
            I love this plug in. If it did batches or mixed selections I'd be over the moon. I like to make all my furniture and appliances proxies and switch them back for viewing or publishing but doing them one at a time is a bummer.
            cfcaia.com
            • sdmitchS
              sdmitch
              cc, I have sent you, by personal message, my version of Bounding Box View. It works with individual components or a selection.
              http://sdmitch.blogspot.com/
              • ccaponigroC
                ccaponigro
                Got it and using it! Works great I place all my heavy components on a layer and use select all on layer and bingo a punch of simple boxes.
                Here is a little trick. Some times snaping to a point on some components can be a pain. So I just make a proxy move or copy it using the proxy rectangle which is easy to find points on and then just switch it back.
                Anyway thanks!!!
                cfcaia.com
                  Spartipilo
                  I liked a lot this plugin, until I had a bugsplat, and my autosave didn't store the original models of the proxy cubes.
                    rutpin
                    I installed the finder plugin but I can't find it in my Scap, I right-click and it's not found, what do I do?
                    • P
                      pedroaugsto Newcomers
                      Proxy View plugin does not reveal the component.
                      Suddenly the plugin stopped working, and I have all my blocks stuck in the proxy. Not returning to component.
                      • G
                        gallucpa
                        Funziona correttamente, ... v.2013, ... per ora, πŸ™‚
                        • 2 / 2
