    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Progress is steady but these types of irregular walls present a few more challenges than normal:
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Testing garage doors and doors:
        design.medeek.com
        • medeekM
          medeek
          Custom or "complex" walls are really no different than complex roofs or floors. They are defined by an array of points. I was just going to adapt my current "Outline Edit" method for Custom walls but I felt like it was time for a bit of an upgrade. I'm hoping people will find this new tool a bit more intuitive. After I fully test it I may incorporate the same logic/tool into the other plugins for the following: Complex Roofs, Floors, Slab-on-Grad foundations, Polyline Stemwalls and Railings
          design.medeek.com
          • medeekM
            medeek
            Version 4.6.8 - 07.06.2026
            • Added a new "Custom" wall option in the Gable Wall tool.
            • Added Doors, Windows and Garage Doors for Custom walls.
            • Created a new interactive Custom Wall profile editing tool.
            This new "custom" wall is still not quite ready for prime time, however I want to put it out there so that the power users can BETA test it for me and tell me what works for them and what does not. I still need to add in all the advanced options and I'm sure there are a few holdovers from the previous wall menu (ie. Wall Height and Wall Length) that are not relevant to this wall type.
            Please be advised that this new wall type is not production ready. Right now it is for testing purposes only.
            design.medeek.com
            • medeekM
              medeek
              First look at cavity insulation for custom walls:
              design.medeek.com
              • medeekM
                medeek
                First look at exterior trim applied to custom walls:
                design.medeek.com
                • medeekM
                  medeek
                  First look at wainscot applied to Custom walls.
                  design.medeek.com
                  • medeekM
                    medeek
                    First look at quoins applied to Custom walls.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 4.6.9 - 07.16.2026
                      Enabled advanced options for Custom walls.
                      Currently the custom wall draw tool requires that a face be draw and then selected to draw a custom wall. I think I also need to allow for a point-by-point polyline method. I will give this some further consideration tomorrow.
                      I also think it might be convenient to be able to switch a rectangular wall to a custom wall, however the ability to switch back will be disabled or disallowed since a custom wall will potentially have too many points that define it so it can’t be cleanly converted back into a rectangular profile, I will need to give this some additional thought.
                      design.medeek.com
                      Reply Quote 2
                      • medeekM
                        medeek
                        Tutorial 92: Custom Walls - (14:47 min)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 4.7.0b - 07.20.2026
                          • Added a floating grid to the Custom wall draw and profile edit tool when the "Grid Snap" option is toggled on.
                          design.medeek.com
                          Reply Quote 2
                            That's a really clever UI helper.
                            • medeekM
                              medeek
                              Version 4.7.1b - 07.29.2026
                              • Fixed a bug with multi-trimmer stud windows.
                              !!! WARNING !!!
                              This is a critical bug fix. The bug was most likely introduced with Version 4.6.8 and has persisted through all versions until this version (4.7.1b). Please update your extension as your earliest convenience.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 4.7.2 - 08.31.2026
                                • Updated the opening move tool with additional construction dimensions.
                                • Updated the column move tool with additional construction dimensions.
                                • Fixed a minor bug in the stair module (riser materials).
                                design.medeek.com
                                • 77
                                • 78
                                • 79
                                • 80
                                • 81
                                • 80 / 81
