    [Plugin] Xref Manager
    98 Posts 43 Posters 95.8k Views 43 Watching
      db11
      @tig said:
      So it currently stays near the bottom of my to-do list
      TIG -
      What if you turned it into a paid extension β€” might that move it up the list?
      At least then, the effort to re-code would have some possibility of reward.
      Seems to me that people that have a need for Xref would likely be willing to pay for the needed functionality for complex and/or collaborative projects... I know that I would.
      For that matter you could take pre-orders and start working on it once you reach a viability threshold.
      Just some ideas to maybe coax it up the to-do list πŸ˜‰
      Doug
      • JQLJ Offline
        JQL
        I'd be very interested in a pro version too.
        www.casca.pt
        Visit us on facebook!
        • Bob JamesB Offline
          Bob James
          Well, that's three orders 😎
          • jujuJ Offline
            juju
            +1!!!
              davecoopstl
              Hi TIG,
              Any chance that you've already updated the X-Ref Manager extension, and are just waiting to release it for the world to use?!?
              Seriously, I'm running into the same "no scroll bar" problem as above, and would love to be able to keep adding X-Refs into my base model, instead of reference them into separate files that then get referenced into the base model.
              And yes, we're willing to PAY you $$ to make it happen! It's THAT valuable for our workflow.
              Let us know!
              Dave Coop.
              • X Offline
                XenoEnder
                I'm currently looking to include this plugin in my workflow, but I can't get the dialog to come up when the file opens to fix outdated xrefs. If This doesn't work, I will need to find another option. Is there something I can do to fix this?
                Edit:
                So it turns out, the xref manager only seems to load at startup if the file is opened from windows explorer, but not by opening the file within sketchup...? Would that be an easy fix?
                  ctrlaltf1
                  Im SKP 2017.
                  I get an "unsigned" message in the extension manager and the plug in wont run.
                  any ideas?
                  • FrederikF Offline
                    Frederik
                    Although this is an old plugin, I just discovered it and I sure could also use it in my work flow... πŸ˜„
                    Cheers
                    Kim Frederik
                      @ctrlaltf1 said:
                      Im SKP 2017.
                      any ideas?
                      Set your Extension Loading Policy to 'Urestricted' otherwise many older plugins will be blocked...
                      • ElibjrE Offline
                        Elibjr
                        After almost 18 years of using it, this is still one of my favorite plugins for working on huge and highly detailed projects! Hat's off to you sir! This is a must have plugin for anyone working collaboratively with others or working on huge project where various people have specific areas they need to work on and they need to isolate their work.
                        • 5 / 5
