    Sketchup make 2017 export to dwg
    4 Posts 4 Posters 925 Views 3 Watching
    • C
      corinne74
      I'm using SketchUp Make 2017. How can I export to DWG format? How can I export to PDF format?
        As a hobbyist version of SketchUp, there's no support for vector exports like .dwg. You could get a subscription for the current version of SketchUp for Desktop or a Go Subscription which gives you access to a web based version that can do the export. You could also look at AutoCAD for importing the .skp file instead.
        If you are using SketchUp as part of your work you need to be using an appropriate version. SketchUp Make is not appropriate for commercial use. Looking back at your previous activity here it looks like you were told this four years ago.
          If you are sticking to Sketchup 2017, you may need to look to Blender for anything dwg. I believe you can export as stl but it's been a while.
          • G
            Glenn at home
            pCon Planner can import any SU and export to any dwg version and vice-versa.
