<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sketchup make 2017 export to dwg]]></title><description><![CDATA[<p dir="auto">I'm using SketchUp Make 2017. How can I export to DWG format? How can I export to PDF format?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.sketchucation.com/topic/164868/sketchup-make-2017-export-to-dwg</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 11:30:37 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/164868.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 May 2026 19:06:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sketchup make 2017 export to dwg on Thu, 14 May 2026 01:21:16 GMT]]></title><description><![CDATA[<p dir="auto">pCon Planner can import any SU and export to any dwg version and vice-versa.</p>
]]></description><link>https://community.sketchucation.com/post/1620652</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620652</guid><dc:creator><![CDATA[Glenn at home]]></dc:creator><pubDate>Thu, 14 May 2026 01:21:16 GMT</pubDate></item><item><title><![CDATA[Reply to Sketchup make 2017 export to dwg on Thu, 14 May 2026 01:16:40 GMT]]></title><description><![CDATA[<p dir="auto">If you are sticking to Sketchup 2017, you may need to look to Blender for anything dwg.  I believe you can export as stl but it's been a while.</p>
]]></description><link>https://community.sketchucation.com/post/1620651</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620651</guid><dc:creator><![CDATA[Mike Amos]]></dc:creator><pubDate>Thu, 14 May 2026 01:16:40 GMT</pubDate></item><item><title><![CDATA[Reply to Sketchup make 2017 export to dwg on Wed, 13 May 2026 22:55:25 GMT]]></title><description><![CDATA[<p dir="auto">As a hobbyist version of SketchUp, there's no support for vector exports like .dwg. You could get a subscription for the current version of SketchUp for Desktop or a Go Subscription which gives you access to a web based version that can do the export. You could also look at AutoCAD for importing the .skp file instead.</p>
<p dir="auto">If you are using SketchUp as part of your work you need to be using an appropriate version. SketchUp Make is not appropriate for commercial use. Looking back at your previous activity here it looks like you were told this four years ago.</p>
]]></description><link>https://community.sketchucation.com/post/1620650</link><guid isPermaLink="true">https://community.sketchucation.com/post/1620650</guid><dc:creator><![CDATA[Dave R]]></dc:creator><pubDate>Wed, 13 May 2026 22:55:25 GMT</pubDate></item></channel></rss>
