    Fredo6 Plugins automatic focus on modal missing since Sketchup2024
    6 Posts 4 Posters 300 Views 4 Watching
      jouschka Newcomers
      I didn't found a support form for Fredo6 plugins. SO maybe this is the correct place.
      In prior Sketchup versions, Fredo6 modals (which you can open with TAB and entering dimensions) where focused on open. I didn't have to click inside the input. Is there any toggle to re-enable this? Or maybe fixed in upstream/fredo6 plugins?
      cheers,
      J
        kostiaarh
        this is a problem with the latest sketchup update
        • fredo6F Offline
          I confirm. And there is nothing I can do (or other scripts can do) as this is an issue in the Sketchup API itself.
          panixiaP 1 Reply Last reply Reply Quote 0
            jouschka Newcomers
            Should I create an issue at Trimble? Or is there already on which I can +1?
            However, thanks for your replies!!!
            fredo6F 1 Reply Last reply Reply Quote 1
            • panixiaP Offline
              panixia @fredo6
              Well, actually I've found myself in the same exact situation with the TAB key causing the viewport to lose focus in SU2023+, but i guess I've managed to find a working solution for this in a couple of plugins.
              Check your inbox, is included in the things I shared today.
              • fredo6F Offline
                fredo6 @jouschka
                The issue is there.
