    ClothWorks – Create Cloth not working in SketchUp 2025 (Mac)
    2 Posts 2 Posters 374 Views 2 Watching
    • B
      bquaquaro Newcomers
      Hello Anton,
      I am using:
      SketchUp 2025 (Version 25.0.659)
      macOS (MacBook)
      ClothWorks 7.1a – license active (Normal, Infinite validity)
      The plugin loads correctly, license is active, UI works, but:
      When I:
      Create a simple rectangle
      Make it a group
      Select the group (bounding box visible)
      Click “Create Cloth”
      Nothing happens.
      The Cloth tab still shows: “none selected – edit materials only”.
      I tested:
      In a completely new file
      With only one single planar face
      With no other plugins interfering
      After resetting preferences
      After reinstalling ClothWorks and SketchUcation tools
      Push/Pull and other tools work correctly.
      It seems Create Cloth does not initialize the cloth object in SU2025 on Mac.
      Could this be a compatibility issue with SketchUp 2025?
      Thank you in advance.
      Best regards,
      benedetto
        Did you open the Ruby Console while performing steps? Error msgs ?
