    [REQ] Tool to reset AND align group/component axes
    14 Posts 6 Posters 1.8k Views 6 Watching
      Rest to best fit bounding box. There was something that did that Maybe it was on the Ruby Depot?
      I do remember it though.
        rv1974
        Thanks Rich, never saw it before. But I can't find this tool after inserting into Plugins folder though. 😞
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=335
        • PixeroP Offline
          Pixero
          Looking at the code it doesn't seem to have a UI or menu.
          Try typing resetAxis in the ruby console.
          Maybe someone can make a menu for it?
          Edit: Nope that didn't work. I get a:
          Error; #<ArgumentError; wrong number of arguments (0 for 1)>
          C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/reset_axes_to_bounding_box_center.rb;2;in `resetAxis'
          <main>;in `<main>'
          SketchUp;1;in `eval'
            rv1974
            Interesting, whether it treated multiple items (before get broken). It'd be awesome to get it back.
            • sumasterS Offline
              sumaster
              can any one upload the script "reset_axes_to_bounding_box_center.rb" .
              http://rhin.crai.archi.fr/rld/plugin_details.php?id=335 web site is dead
              thanks
              Thank you,
              SUmaster
              Didier BurD 1 Reply Last reply Reply Quote 0
              • Didier BurD Offline
                Didier Bur @sumaster
                @sumaster :
                I was the webmaster of the former 'Ruby Depot' and found what you are after on a (very) old external disk. I've enhanced it a bit (selection control, command in the 'Tools' menu, bugs fixed).
                It works for groups and components, but be aware that it will NOT re-orient the bounding box.
                Regards,
                (Put it in your Plugins folder):
                resetaxisofcomponent.rb
                DB
                sumasterS 1 Reply Last reply πŸ‘ Reply Quote 0
                  rv1974
                  SU4U > Reset Axis
                  sumasterS Didier BurD 2 Replies Last reply πŸ‘ Reply Quote 0
                  • sumasterS Offline
                    sumaster @Didier Bur
                    @Didier-Bur
                    yes check it work selected group or component axes move to center but not fit bounding to geometry.
                    but thank you so much . . . . πŸ™‚
                    Thank you,
                    SUmaster
                    • sumasterS Offline
                      sumaster @rv1974
                      @rv1974
                      Yes, i think this plugin rest axes and fit bounding to geometry
                      Thanks . . . πŸ™‚
                      Thank you,
                      SUmaster
                        Didier Bur @rv1974
                        @rv1974
                        It doesn't work on my side, I get this:
                        Error: #<NameError: uninitialized constant S4U::S4u_License
                        Did you mean? SCFLicense>
                        ..../sketchup/plugins/s4u_reset_axis/s4u_reset_axis_code.rbe:374:in `main'
                        ..../sketchup/plugins/s4u_reset_axis/s4u_reset_axis_loader.rbe:26:in `block (2 levels) in module:S4u_reset_axis'
                        Any hint ?
                        DB
                        R 1 Reply Last reply Reply Quote 0
                          rv1974 @Didier Bur
                          @Didier-Bur wild guess- the trial is over and you need to purchase?
                            Didier Bur @rv1974
                            @rv1974
                            the script is supposed to be free...
                            DB
                              rv1974
                              Yep, I hate this part - they are too shy to indicate it's commercial, they ALL are FrEe. Here on sketchucation they do show $ sign
