    [REQ] Tool to reset AND align group/component axes
    14 Posts 6 Posters 1.4k Views 6 Watching
      MrWip
      Hi everyone,
      Working more and more with complex BIM models export, imported into sketchup, I'm regularly facing the same issue : All the build elements are groups (sometimes components), which are fine to work with, but their axes are always set relatively to the world axes, and not along there respective most logical direction, which make them really hard to use (textures projection is not right, scaling is impossible...)
      So, my question is the following : could there be a plugin allowing an automatic axes reorientation, of a selected amount of object, along their most logical axes ?
      Working regularly with the great FredoTool box scaling, I noticed that this tool was able to orient itself automatically really well, along what i called previously "the most logical axes".
      So, could it be possible to use a similar method to reorient each group axes ?
      ... In fact there is maybe a plugin allowing that already, but I couldn't find it. The closest thing was ThomThom axes tool, but it's not reorienting the axes, just reseting their origin...
      Thanks in advance.
      http://www.wip-archi.com
        Rest to best fit bounding box. There was something that did that Maybe it was on the Ruby Depot?
        I do remember it though.
        • R Do not disturb
          rv1974
          Thanks Rich, never saw it before. But I can't find this tool after inserting into Plugins folder though. 😞
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=335
          • PixeroP Offline
            Pixero
            Looking at the code it doesn't seem to have a UI or menu.
            Try typing resetAxis in the ruby console.
            Maybe someone can make a menu for it?
            Edit: Nope that didn't work. I get a:
            Error; #<ArgumentError; wrong number of arguments (0 for 1)>
            C;/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/reset_axes_to_bounding_box_center.rb;2;in `resetAxis'
            <main>;in `<main>'
            SketchUp;1;in `eval'
            • R Do not disturb
              rv1974
              Interesting, whether it treated multiple items (before get broken). It'd be awesome to get it back.
              • sumasterS Offline
                sumaster
                can any one upload the script "reset_axes_to_bounding_box_center.rb" .
                http://rhin.crai.archi.fr/rld/plugin_details.php?id=335 web site is dead
                thanks
                Thank you,
                SUmaster
                Didier BurD 1 Reply Last reply Reply Quote 0
                • Didier BurD Offline
                  Didier Bur @sumaster
                  @sumaster :
                  I was the webmaster of the former 'Ruby Depot' and found what you are after on a (very) old external disk. I've enhanced it a bit (selection control, command in the 'Tools' menu, bugs fixed).
                  It works for groups and components, but be aware that it will NOT re-orient the bounding box.
                  Regards,
                  (Put it in your Plugins folder):
                  resetaxisofcomponent.rb
                  DB
                  sumasterS 1 Reply Last reply πŸ‘ Reply Quote 0
                  • R Do not disturb
                    rv1974
                    SU4U > Reset Axis
                    sumasterS Didier BurD 2 Replies Last reply πŸ‘ Reply Quote 0
                    • sumasterS Offline
                      sumaster @Didier Bur
                      @Didier-Bur
                      yes check it work selected group or component axes move to center but not fit bounding to geometry.
                      but thank you so much . . . . πŸ™‚
                      Thank you,
                      SUmaster
                      • sumasterS Offline
                        sumaster @rv1974
                        @rv1974
                        Yes, i think this plugin rest axes and fit bounding to geometry
                        Thanks . . . πŸ™‚
                        Thank you,
                        SUmaster
                          Didier Bur @rv1974
                          @rv1974
                          It doesn't work on my side, I get this:
                          Error: #<NameError: uninitialized constant S4U::S4u_License
                          Did you mean? SCFLicense>
                          ..../sketchup/plugins/s4u_reset_axis/s4u_reset_axis_code.rbe:374:in `main'
                          ..../sketchup/plugins/s4u_reset_axis/s4u_reset_axis_loader.rbe:26:in `block (2 levels) in module:S4u_reset_axis'
                          Any hint ?
                          DB
                          R 1 Reply Last reply Reply Quote 0
                          • R Do not disturb
                            rv1974 @Didier Bur
                            @Didier-Bur wild guess- the trial is over and you need to purchase?
                              Didier Bur @rv1974
                              @rv1974
                              the script is supposed to be free...
                              DB
                              • R Do not disturb
                                rv1974
                                Yep, I hate this part - they are too shy to indicate it's commercial, they ALL are FrEe. Here on sketchucation they do show $ sign
