    Plugins to add random textures to random components?
    5 Posts 3 Posters 662 Views 3 Watching
      Jorgensen
      Hi all
      I’m looking for a way to create a trustworthy looking brick wall.
      I have modelled a brick wall using several components, and I’m now looking for a way to texture it.
      I have found some random tools, that lets me select a random selection of already selected components, and then manually select materials to the selected components.
      What could be nice for this, would be a plugin that
      • let’s me select 3-10 different materials
      • assigns the material in a random order
      • to the selected components
      Or there might be an even better way to achieve what I’m looking for?
      Best regards
      Jorgensen
        You could create a bunch of brick textures if you want but I would skip making the brick components and then use a texture made from a photo of a large wall. This is from one of my brick textures. It's quite a bit larger than I show but I can pick out different sections of it as needed. Can't get any more "trustworthy" than that.
          Jorgensen
          Hi dave
          i totally agree - using a texture, gives the most "trustworthy" realistic result.
          the challenge is, that i'm experimenting with different kinds of brick details, so i don't think i can use a texture, as i normally would do.
            If you want to swap out textures you can try MatSim by fredo
            SketchUp Plugins | PluginStore | SketchUcation
            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
            (sketchucation.com)
            https://youtu.be/0m0ttNwrI_c
              Jorgensen
              ah thanks rich - ill give it a try 🙂
