    [Plugin] Smooth Zoom 2.1.0 - 24 October 2021
    76 Posts 31 Posters 83.5k Views 30 Watching
    • Rich O BrienR Online
      Anton is aware of this errors. Expect a fix asap
      • TIGT Online
        Until there's a fix available, because the error is in a RB file you can edit it with a plain-text editor like Notepad++.exe
        Find where it says File.exists? and change it to File.exist?
        Both method coexisted for ever and were equivalent to each other, but in >=v2024 someone chose to deprecate the original correct-English sounding version, and cause authors issues.
        After you save that edit restart SketchUp to see if that fixed it...
          kurdoc69 @Anton_S
          @Anton_S HELLO FRIEND, CAN YOU MAKE IT WORK ON VERSION 2025 ? IT IS MY ESSENTIAL COMPONENT ! THANK Y👏 OU
          TIGT 1 Reply Last reply Reply Quote 0
          • TIGT Online
            TIG Moderator @kurdoc69
            @kurdoc69
            Read my reply above yours, it outlines how to do a manual fix on the RB file, until the author responds.
            K 1 Reply Last reply Reply Quote 0
              kurdoc69 @TIG
              @TIG i downloaded notepad++ but my file is rbz, when i open it i can't understand the language to edit, sorry i don't understand about this.
              • TIGT Online
                You need to install it into v2025 from the RBZ - with errors.
                Then close SketchUp and find the RB file in your Plugins folder, open it it with Notepad++.exe and do the edit as outlined above...
                The installed file is C:/Users/YOURUSERNAME/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb
                  kurdoc69 @TIG
                  @TIG I changed 3 places where it said File.exists? and then I get this new error
                  Informe de errores de extensión
                  SketchUp: 25.0.571
                  OS: Windows 11
                  Ruby: 3.2.2
                  Extensión: SoothZoom (2.1.1a)
                  Error: IOError (Stage directory, "C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/libraries/stage/win64/3.2", is missing!)
                  C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/extension_manager.rb:76:in require_all' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main.rb:95:in <top (required)>'
                  C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in require' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom/main_entry.rb:19:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2025/SketchUp/Tools/extensions.rb:197:in load'
                  C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:42:in register_extension' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:42:in module:SmoothZoom'
                  C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:10:in <module:AMS>' C:/Users/Kurdo/AppData/Roaming/SketchUp/SketchUp 2025/SketchUp/Plugins/ams_SmoothZoom.rb:9:in <top (required)>'
                  • TIGT Online
                    So that error seems to relate to a missing directory or file.
                    You need to wait for the author to resolve this .
                    Sorry.
                      kurdoc69 @TIG
                      @TIG thank you for your support
                        shepyura
                        Помогите! 2024 не работает! SOS)!ПОЖАЛУЙСТА!
                        • TIGT Online
                          The earlier posts in this thread explain how to make a temporary fix by editing the RB file.
                          В предыдущих сообщениях в этой теме объясняется, как сделать временное исправление путем редактирования файла RB.
                          • 3 / 4
