    3D Truss Models
    1.5k Posts 31 Posters 976.2k Views 30 Watching
    • medeekM Offline
      medeek
      Version 3.6.6 - 03.21.2025
      • Added the option to specify a separate front and back gable overhang length for all truss types.
      • Augmented the web generation algorithm for coffer trusses with deep coffer ceilings.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.6.7 - 04.06.2025
        • Added collar ties for symmetric and asymmetric gable rafter roofs.
        • Fixed a bug with gable wall cladding for all truss types.
        Note that the height of the collar tie is measured from the bottom of the ridge board. A zero height puts the collar tie against the bottom of the ridge board.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.6.8 - 04.07.2025
          • Enabled square cut top chord tails for the following truss types: common, attic, scissor and cathedral.
          design.medeek.com
          • medeekM Offline
            medeek
            Tutorial 32: Square Cut Truss Tails (7:43 min.)
            design.medeek.com
            • medeekM Offline
              medeek
              At the behest of some users who use this plugin for large agricultural buildings, I will be adding at couple more options for large trusses. Specifically a “Quad Howe” and a “Penta Howe” common truss option. The “Penta Howe” truss is suitable for trusses that measure up to 100’ in span (or greater). I had a little fun with this :slight_smile:
              The barn I show with the tractor has a 92’ span truss with a 36" raised heel. Top and bottom chords are 2x8 with 2x6 webs. The trusses are double ply (3" width) and spaced at 4’ on center.
              After I modeled this, I thought, what could a guy do with a garage like this? Okay, realistically I don’t need an aircraft hanger for a garage, but 36’x36’ sure would be nice.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.6.9 - 04.10.2025
                • Enabled options for wood grain texture for lumber in the global settings.
                • Enabled wood grain texture for common and scissor trusses.
                • Added a Quad Howe and Penta Howe option for common trusses.
                • Fixed a minor bug with 4/2 scissor trusses with raised heels.
                • Fixed a minor bug with the bottom chord of certain common trusses.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.7.0 - 04.13.2025
                  • Enabled wood grain texture for the following truss types: attic, symmetric cathedral, cathedral, cambered, tail bearing, coffer, tray, and parallel chord.
                  • Added the following Parallel Chord truss type: 10/10.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.7.1 - 04.18.2025
                    • Enabled wood grain texture for the following truss types: flat.
                    • Added metal plates for all attic trusses.
                    • Added an attic furring option for attic trusses.
                    • Fixed a minor bug in the gable cut option for attic trusses.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.7.2 - 04.22.2025
                      • Enabled wood grain texture for the following truss types: gambrel attic, monopitch, monocathedral, monoscissor, polynesian, dual pitch, bowstring, bow barrel.
                      • Enabled wood grain texture for the following rafter roof types: gable, gable w/ glulam.
                      • Added the follow Monopitch truss type configuration: (4/4).
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.7.3 - 07.19.2025
                        • Enabled square cut rafter tails for gable rafter roofs.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.7.5 - 01.03.2026
                          • Enabled hurricane ties for all remaining common trusses.
                          • Enabled hurricane ties for scissor, cathedral, polynesian and dual pitch trusses.
                          • Fixed a (metric) bug for the inset parameter for hurricane ties.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.7.6 - 01.07.2026
                            • Added an offset parameter for coffer trusses (non-raised heel only).
                            design.medeek.com
                            • 72
                            • 73
                            • 74
                            • 75
                            • 76
                            • 74 / 76
