    3D Truss Models
    1.5k Posts 32 Posters 1.7m Views 31 Watching
    • medeekM Offline
      medeek
      Version 3.6.6 - 03.21.2025
      • Added the option to specify a separate front and back gable overhang length for all truss types.
      • Augmented the web generation algorithm for coffer trusses with deep coffer ceilings.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.6.7 - 04.06.2025
        • Added collar ties for symmetric and asymmetric gable rafter roofs.
        • Fixed a bug with gable wall cladding for all truss types.
        Note that the height of the collar tie is measured from the bottom of the ridge board. A zero height puts the collar tie against the bottom of the ridge board.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.6.8 - 04.07.2025
          • Enabled square cut top chord tails for the following truss types: common, attic, scissor and cathedral.
          design.medeek.com
          • medeekM Offline
            medeek
            Tutorial 32: Square Cut Truss Tails (7:43 min.)
            design.medeek.com
            • medeekM Offline
              medeek
              At the behest of some users who use this plugin for large agricultural buildings, I will be adding at couple more options for large trusses. Specifically a “Quad Howe” and a “Penta Howe” common truss option. The “Penta Howe” truss is suitable for trusses that measure up to 100’ in span (or greater). I had a little fun with this :slight_smile:
              The barn I show with the tractor has a 92’ span truss with a 36" raised heel. Top and bottom chords are 2x8 with 2x6 webs. The trusses are double ply (3" width) and spaced at 4’ on center.
              After I modeled this, I thought, what could a guy do with a garage like this? Okay, realistically I don’t need an aircraft hanger for a garage, but 36’x36’ sure would be nice.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.6.9 - 04.10.2025
                • Enabled options for wood grain texture for lumber in the global settings.
                • Enabled wood grain texture for common and scissor trusses.
                • Added a Quad Howe and Penta Howe option for common trusses.
                • Fixed a minor bug with 4/2 scissor trusses with raised heels.
                • Fixed a minor bug with the bottom chord of certain common trusses.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.7.0 - 04.13.2025
                  • Enabled wood grain texture for the following truss types: attic, symmetric cathedral, cathedral, cambered, tail bearing, coffer, tray, and parallel chord.
                  • Added the following Parallel Chord truss type: 10/10.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.7.1 - 04.18.2025
                    • Enabled wood grain texture for the following truss types: flat.
                    • Added metal plates for all attic trusses.
                    • Added an attic furring option for attic trusses.
                    • Fixed a minor bug in the gable cut option for attic trusses.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.7.2 - 04.22.2025
                      • Enabled wood grain texture for the following truss types: gambrel attic, monopitch, monocathedral, monoscissor, polynesian, dual pitch, bowstring, bow barrel.
                      • Enabled wood grain texture for the following rafter roof types: gable, gable w/ glulam.
                      • Added the follow Monopitch truss type configuration: (4/4).
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.7.3 - 07.19.2025
                        • Enabled square cut rafter tails for gable rafter roofs.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.7.5 - 01.03.2026
                          • Enabled hurricane ties for all remaining common trusses.
                          • Enabled hurricane ties for scissor, cathedral, polynesian and dual pitch trusses.
                          • Fixed a (metric) bug for the inset parameter for hurricane ties.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.7.6 - 01.07.2026
                            • Added an offset parameter for coffer trusses (non-raised heel only).
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.7.8 - 03.24.2026
                              • Created the Medeek Truss API.
                              • Enabled the following methods within the Medeek Truss API: common_truss_draw, validate_medeektruss, truss_regen, common_truss_read_attributes, common_truss_get_attribute, common_truss_set_attribute
                              • Added the Medeek Truss API Documentation page to the website.
                              • Added the Medeek Truss API - Common Truss Attribute Library Index page to the website.
                              (design.medeek.com)
                              (design.medeek.com)
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.7.9 - 03.27.2026
                                • Enabled the following methods within the Medeek Truss API: scissor_truss_draw.
                                • Consolidated the API code so that it is lightweight on extension load.
                                • Renamed the following API methods: common_truss_read_attributes, common_truss_get_attribute, common_truss_set_attribute, to the more correct general names: truss_read_attributes, truss_get_attribute, truss_set_attribute.
                                Medeek Truss API - Scissor Truss Attribute Library Index
                                (design.medeek.com)
                                As one can see each truss family typically has a unique set of parameters so each will require a separate "draw" method as well as a documented attribute library index. Only about 18 more truss families to go...
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.8.0 - 03.29.2026
                                  • Enabled the following methods within the Medeek Truss API: attic_truss_draw, cathedral_truss_draw.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      I've had a couple requests in the last week that I finish the Complex Truss module. The last time I worked in earnest on the complex roof module was about four years ago now. At that time my attempts to come up with a successful algorithm for laying out the trusses were not successful.
                                      I thought I might revisit the topic again today with the additional interest shown. However after giving this some thought and creating some various tests I'm still not sure how to do it. Additionally even if I did create an algorithm it would need to be able to handle some interesting cases and do a number of checks.
                                      Case in point look at the roof below, manually framed with simplified truss place holders. I've provided the rafter framing for comparison (automatically produced by the complex rafter module). This would be your typical complex roof, lots of roof planes and no apparent good method to truss it out. My problem is the red colored truss, it is too shallow in a couple spots.
                                      I guess what I'm saying is that even if I create an algorithm which can get one to this point, I still don't even know if it is correct or will work. I would love to gather some feedback and thoughts on how to frame this out with trusses from those who are working or have worked in the industry.
                                      truss_su917_800.jpg truss_su918_800.jpg truss_su919_800.jpg truss_su920_800.jpg truss_su921_800.jpg truss_su922_800.jpg truss_su923_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Here is another example, a much simpler L-shaped footprint with one main girder and three hip girders:
                                        Even this roof has a suspect truss (shaded red), that I am uncertain about. Arguably this one is so simple one could truncate the smaller hip set and then run a valley set up onto the main roof (hip set). However without any overframing I think this is what you end up with. The irregular trusses are shaded in purple and have had their webbing removed.
                                        If anyone has some truss layout plans (PDF) for complex roofs that they would not mind sharing with me that would be very much appreciated. I am specifically looking for a full set, ie. the truss layout and then the shop plans that show each truss profile. I need to study this further.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I've been pondering how to control the truss layout of these complex roofs and after much thought and sleeping on the problem for a night I've come to the conclusion that for all but the simplest roof types (gable or half hip both ends on a rectangular footprint) there needs to be user specified girder trusses.
                                          Even the simplest hip roof (rectangular, hip both ends) needs two girder trusses. The algorithm should be smart enough to detect the layout in such a simple case but even so the setback of those girder trusses will have to be user controlled. With my existing hip set tools this is provided as a simple numeric value since the location and orientation of the hip girders is already determined.
                                          When you move to complex roofs the location of the girders becomes completely open ended. In other words we have too many degrees of freedom to confidently compute the solution. You can't solve a multi-variable math problem if you have more variables than you have constraints or equations. That is the nature of this beast.
                                          My thinking is this:
                                          1.) The user creates the perimeter or outline of the complex truss roof just as one currently does with the complex rafter module. The general roof shape and secondary features are generated (ie. sub-fascia, sheathing, cladding, gutter, soffit and fascia etc...), however the actual truss framing is not generated with this initial creation step.
                                          2.) Next, the user clicks the girder truss creation tool which allows one to add in specific girder trusses between any two points within the roof outline (layer). The algorithm will require that the two endpoints of the new girder either terminate on the perimeter or along the length of an existing girder. Obviously the new girder cannot have both of its points on a perimeter edge or another girder, so that check will be built in. An HTML dialog box will allow the user to set a number of properties of the girder (ie. 2-ply, top chord depth, bottom chord depth, truss configuration, panel number for hip girders etc...)
                                          3.) Once the girders are set then a context menu option will allow the user to attempt to generate the actual truss framing. If the girder layout is inconsistent, or illogical it will fail and display the applicable warning to the user. I'm still feeling this one out a bit so there may be an additional step where the user determines the rotation of the trusses in each zone created by the girder trusses.
                                          I think I can make this work but only time and some extensively testing will tell. I think the concept is fundamentally sound but as I've learned in the past with other programming problems, the devil is in the details
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Here is an excellent example of a complex roof that involves multiple girders and overframing using valley sets:
                                            What I find particularly interesting with this case is the use of the half valley set on the right hand side. Why is this? This is cause for more investigation.
                                            This next one is a bit confusing because it shows multiple levels of roofs, but the doubled up hip is what is most interesting, specifically trusses 08 being carried by the cross girder 14 which is then carried by girder 04. The shaded region over this section is to be framed onsite per the notes, or optionally one could valley truss this out with a half valley set, I’m starting to see a pattern here and I think I know why.
                                            design.medeek.com
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 75 / 77
