    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      Tutorial 31: Wrap Around Porch Roof (17:26 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I've started working on adding in a scissor truss option into the module. Here are some quick and dirty (sorry I must have set my lunch down on my engineering pad earlier today) calcs for the heel joint of such a truss:
        design.medeek.com
        • medeekM
          medeek
          Version 3.6.4 - 03.13.2025
          • Enabled subtractive geometry for all dutch gable rafter roofs.
          design.medeek.com
          • medeekM
            medeek
            Version 3.6.4b - 03.15.2025
            • Enabled subtractive geometry for all TJI and Glulam Beam rafter roofs.
            design.medeek.com
            • medeekM
              medeek
              Version 3.6.5 - 03.16.2025
              • Added energy/raised heels for coffer trusses (3 variants: wedge, slider and vertical w/ strut).
              • Enabled a feature to selectively remove specific trusses from coffer truss assemblies.
              design.medeek.com
              Reply Quote 2
              • medeekM
                medeek
                Version 3.6.6 - 03.21.2025
                • Added the option to specify a separate front and back gable overhang length for all truss types.
                • Augmented the web generation algorithm for coffer trusses with deep coffer ceilings.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.6.7 - 04.06.2025
                  • Added collar ties for symmetric and asymmetric gable rafter roofs.
                  • Fixed a bug with gable wall cladding for all truss types.
                  Note that the height of the collar tie is measured from the bottom of the ridge board. A zero height puts the collar tie against the bottom of the ridge board.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.6.8 - 04.07.2025
                    • Enabled square cut top chord tails for the following truss types: common, attic, scissor and cathedral.
                    design.medeek.com
                    • medeekM
                      medeek
                      Tutorial 32: Square Cut Truss Tails (7:43 min.)
                      design.medeek.com
                      • medeekM
                        medeek
                        At the behest of some users who use this plugin for large agricultural buildings, I will be adding at couple more options for large trusses. Specifically a “Quad Howe” and a “Penta Howe” common truss option. The “Penta Howe” truss is suitable for trusses that measure up to 100’ in span (or greater). I had a little fun with this :slight_smile:
                        The barn I show with the tractor has a 92’ span truss with a 36" raised heel. Top and bottom chords are 2x8 with 2x6 webs. The trusses are double ply (3" width) and spaced at 4’ on center.
                        After I modeled this, I thought, what could a guy do with a garage like this? Okay, realistically I don’t need an aircraft hanger for a garage, but 36’x36’ sure would be nice.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.6.9 - 04.10.2025
                          • Enabled options for wood grain texture for lumber in the global settings.
                          • Enabled wood grain texture for common and scissor trusses.
                          • Added a Quad Howe and Penta Howe option for common trusses.
                          • Fixed a minor bug with 4/2 scissor trusses with raised heels.
                          • Fixed a minor bug with the bottom chord of certain common trusses.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.7.0 - 04.13.2025
                            • Enabled wood grain texture for the following truss types: attic, symmetric cathedral, cathedral, cambered, tail bearing, coffer, tray, and parallel chord.
                            • Added the following Parallel Chord truss type: 10/10.
                            design.medeek.com
                            Reply Quote 2
                            • medeekM
                              medeek
                              Version 3.7.1 - 04.18.2025
                              • Enabled wood grain texture for the following truss types: flat.
                              • Added metal plates for all attic trusses.
                              • Added an attic furring option for attic trusses.
                              • Fixed a minor bug in the gable cut option for attic trusses.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.7.2 - 04.22.2025
                                • Enabled wood grain texture for the following truss types: gambrel attic, monopitch, monocathedral, monoscissor, polynesian, dual pitch, bowstring, bow barrel.
                                • Enabled wood grain texture for the following rafter roof types: gable, gable w/ glulam.
                                • Added the follow Monopitch truss type configuration: (4/4).
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.7.3 - 07.19.2025
                                  • Enabled square cut rafter tails for gable rafter roofs.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.7.5 - 01.03.2026
                                    • Enabled hurricane ties for all remaining common trusses.
                                    • Enabled hurricane ties for scissor, cathedral, polynesian and dual pitch trusses.
                                    • Fixed a (metric) bug for the inset parameter for hurricane ties.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.7.6 - 01.07.2026
                                      • Added an offset parameter for coffer trusses (non-raised heel only).
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.7.8 - 03.24.2026
                                        • Created the Medeek Truss API.
                                        • Enabled the following methods within the Medeek Truss API: common_truss_draw, validate_medeektruss, truss_regen, common_truss_read_attributes, common_truss_get_attribute, common_truss_set_attribute
                                        • Added the Medeek Truss API Documentation page to the website.
                                        • Added the Medeek Truss API - Common Truss Attribute Library Index page to the website.
                                        (design.medeek.com)
                                        (design.medeek.com)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.7.9 - 03.27.2026
                                          • Enabled the following methods within the Medeek Truss API: scissor_truss_draw.
                                          • Consolidated the API code so that it is lightweight on extension load.
                                          • Renamed the following API methods: common_truss_read_attributes, common_truss_get_attribute, common_truss_set_attribute, to the more correct general names: truss_read_attributes, truss_get_attribute, truss_set_attribute.
                                          Medeek Truss API - Scissor Truss Attribute Library Index
                                          (design.medeek.com)
                                          As one can see each truss family typically has a unique set of parameters so each will require a separate "draw" method as well as a documented attribute library index. Only about 18 more truss families to go...
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.8.0 - 03.29.2026
                                            • Enabled the following methods within the Medeek Truss API: attic_truss_draw, cathedral_truss_draw.
                                            design.medeek.com
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 75 / 77
