    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Version 3.5.0 - 05.26.2024
      • Enabled "flat" ceiling gypsum for dutch gable rafter roofs.
      • Enabled "flat" ceiling gypsum for hip rafter roofs.
      • Fixed a bug with the global settings for rafter and truss roofs when the layer/tags option is turned off.
      alt text
      alt text
      CRITICAL BUG FIX!
      Version 3.4.7 introduced a bug for both rafter and truss roofs when the layers/tags option is turned off. This release fixes that bug. I highly recommend that everyone download this latest update to correct this bug.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      Reply Quote 2
      • medeekM
        medeek
        [b]Version 3.5.2[/b] - 05.30.2024
        • Enabled ceiling insulation for floor trusses: Batt, Blown-in.
        • Enabled ceiling insulation for I-Joist and Lumber floors: Batt, Blown-in.
        • Fixed a bug with ceiling gypsum for inset floors (I-joist and Lumber).
        • Fixed a minor bug with joist hangers for common lumber sizes for inset floors.
        http://design.medeek.com/resources/trussplugin/images5/truss_su853_800.jpg
        http://design.medeek.com/resources/trussplugin/images5/truss_su852_800.jpg
        http://design.medeek.com/resources/trussplugin/images5/truss_su851_800.jpg
        Honestly I didn't want to spend too much time updating this module since the new Floor plugin will supersede it, however since I do intend on retaining it within the Truss plugin for the foreseeable future, I thought it best to bring it up to speed with the other truss assemblies, and add the insulation option.
        Some of these updates seem small now and very incremental however they all take time and energy and they usually involve fairly tedious updates to the attribute library code and the HTML menus.
        The Truss plugin overall probably still has the most work that needs to be done of all the plugins. Compared to the Wall plugin this plugin has many partially finished tools and features and still certain trusses that are missing advanced options. The work will go on.
        design.medeek.com
        gullfoG 1 Reply Last reply
        • gullfoG
          gullfo @medeek
          @medeek thanks! when do you expect to drop the new floor plugin? πŸ™‚
          Glenn
          http://www.runnel.com
          • medeekM
            medeek
            Version 3.5.3 - 06.09.2024
            • Enabled a feature to selectively remove specific trusses from floor truss assemblies.
            • Enabled a feature to selectively remove specific joists from I-joist and lumber floor assemblies.
            https://global.discourse-cdn.com/sketchup/original/3X/6/2/62cc073888d0cfecbea99e04bb25931977baa3cf.jpeg
            https://global.discourse-cdn.com/sketchup/optimized/3X/1/2/12ac1d4971166805986aecd30609d1c3e66215cc_2_690x453.jpeg
            design.medeek.com
            • medeekM
              medeek
              Version 3.5.4 - 06.15.2024
              • Fixed a bug introduced in Version 3.4.7 for all rafter and truss roofs.
              !! Critical Bug Fix !!
              Note that this bug only reveals itself if you have the sub-fascia for the truss or rafter roof turned off. This bug applies to both truss and rafter roofs (gable).
              design.medeek.com
              • medeekM
                medeek
                Version 3.5.5 - 06.22.2024
                • Fixed a bug introduced in Version 3.4.7 for all rafter and truss roofs (when adv. roof options disabled).
                This bug only reveals itself if you turn off the advanced roof options. The bug applies to truss and rafter roofs. I highly recommend updating to this latest version.
                design.medeek.com
                • medeekM
                  medeek
                  The new Rafter Roof menu should be a bit more visual and intuitive for selecting the appropriate roof type:
                  design.medeek.com
                  Reply Quote 2
                  • medeekM
                    medeek
                    Version 3.5.6 - 07.03.2024
                    • Enabled a graphical user interface for Rafter Roof selection.
                    • Enabled a graphical user interface for Floor selection.
                    • Fixed a bug introduced in Version 3.5.3 for all I-joist, lumber and truss floors (when adv. floor options disabled).
                    design.medeek.com
                    Reply Quote 2
                    • medeekM
                      medeek
                      Version 3.5.7 - 07.05.2024
                      • Fixed a bug for all rafter roofs that have glulam beams.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.5.8 - 07.12.2024
                        • Enabled the "Edit Roof Assembly" function for gable rafter roofs with glulam beams (imperial and metric units).
                        • Enabled the "Edit Roof Assembly" function for I-joist rafter roofs with glulam beams (imperial and metric units).
                        • Enabled the "Edit Roof Assembly" function for I-joist rafter roofs with dual glulam beams (imperial and metric units).
                        • Added BCI, LPI, Red-I and PKI I-joists to the rafter roof module (glulam beam and dual glulam beam roofs).
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.6.1 - 07.19.2024
                          • Added Soffit Cut within Advanced Options for Complex Rafter Roofs.
                          • Fixed a critical bug with the complex roof module.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.6.2 - 07.21.2024
                            • Enabled "flat" ceiling gypsum for complex rafter roofs.
                            • Fixed a minor bug with the hip-and-ridge for hip rafter roofs.
                            design.medeek.com
                            • medeekM
                              medeek
                              [b]Version 3.6.3[/b] - 07.26.2024
                              • Added a duplicate roof assembly check to the regen module for rafter, complex and truss roofs.
                              The instructions for usage are the same as the recent update to the Wall plugin, see Wall Plugin Tutorial #51:
                              design.medeek.com
                              • medeekM
                                medeek
                                Tutorial 31: Wrap Around Porch Roof (17:26 min.)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I've started working on adding in a scissor truss option into the module. Here are some quick and dirty (sorry I must have set my lunch down on my engineering pad earlier today) calcs for the heel joint of such a truss:
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.6.4 - 03.13.2025
                                    • Enabled subtractive geometry for all dutch gable rafter roofs.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.6.4b - 03.15.2025
                                      • Enabled subtractive geometry for all TJI and Glulam Beam rafter roofs.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.6.5 - 03.16.2025
                                        • Added energy/raised heels for coffer trusses (3 variants: wedge, slider and vertical w/ strut).
                                        • Enabled a feature to selectively remove specific trusses from coffer truss assemblies.
                                        design.medeek.com
                                        Reply Quote 2
                                        • medeekM
                                          medeek
                                          Version 3.6.6 - 03.21.2025
                                          • Added the option to specify a separate front and back gable overhang length for all truss types.
                                          • Augmented the web generation algorithm for coffer trusses with deep coffer ceilings.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.6.7 - 04.06.2025
                                            • Added collar ties for symmetric and asymmetric gable rafter roofs.
                                            • Fixed a bug with gable wall cladding for all truss types.
                                            Note that the height of the collar tie is measured from the bottom of the ridge board. A zero height puts the collar tie against the bottom of the ridge board.
                                            design.medeek.com
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 75 / 77
