    clothworks and make2017
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    4 Posts 2 Posters 291 Views 2 Watching
      krisboardman Newcomers
      im trying to use the clothworks extension with Make 2017 (v17.2.2555) however the "make cloth" option isn't available even though the license is active. Ive tried re-installing both sketchup and clothworks but the problem persists. any suggestions?
        Is the geometry a group/component? The context menu only displays when the selection meets the the criteria needed.
        K 1 Reply Last reply Reply Quote 0
          krisboardman Newcomers @Rich O Brien
          @Rich-O-Brien
          thanks for the follow up! i was following some bad advice on AI and figured it out once i watched a tutorial. ill be closing this post.
            Extensions > Clothworks > Manual menu is your friend.
            Artificial Intelligence is naturally stupid.
            • Rich O BrienR Rich O Brien marked this topic as a question on
