    JHS Powerbar for SU 2025
    3 Posts 3 Posters 929 Views 3 Watching
    • W Offline
      WHW Newcomers
      I've just downloaded and started using Sketchup 2025 and successfully migrated all my extensions from 2024 with the exception of the JHS Powerbar. I'm told there's no updated version of this. Does anyone at Sketchucation know if and when this is likely to be updated? There are some useful tools on it.
        Did you try installing it correctly using the Sketchucation ExtensionStore tool?
        FWIW, did you use the Sketchucation ExtensionStore tool to install your Sketchucation Bundle? If not, you may have issues with some other extensions. The extension migrator for SU2025 only copies the extensions from a previous installation of SketchUp. It doesn't update them like installing the bundle with the ExtensionStore tool does.
        • grizzlerG Offline
          grizzler
          I hope there's going to be an updated version soon, I miss this plugin 😁
