    3D Truss Models
    1.5k Posts 31 Posters 935.5k Views 30 Watching
    • medeekM Offline
      medeek
      I've started working on adding in a scissor truss option into the module. Here are some quick and dirty (sorry I must have set my lunch down on my engineering pad earlier today) calcs for the heel joint of such a truss:
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.6.4 - 03.13.2025
        • Enabled subtractive geometry for all dutch gable rafter roofs.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.6.4b - 03.15.2025
          • Enabled subtractive geometry for all TJI and Glulam Beam rafter roofs.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.6.5 - 03.16.2025
            • Added energy/raised heels for coffer trusses (3 variants: wedge, slider and vertical w/ strut).
            • Enabled a feature to selectively remove specific trusses from coffer truss assemblies.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.6.6 - 03.21.2025
              • Added the option to specify a separate front and back gable overhang length for all truss types.
              • Augmented the web generation algorithm for coffer trusses with deep coffer ceilings.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.6.7 - 04.06.2025
                • Added collar ties for symmetric and asymmetric gable rafter roofs.
                • Fixed a bug with gable wall cladding for all truss types.
                Note that the height of the collar tie is measured from the bottom of the ridge board. A zero height puts the collar tie against the bottom of the ridge board.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.6.8 - 04.07.2025
                  • Enabled square cut top chord tails for the following truss types: common, attic, scissor and cathedral.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Tutorial 32: Square Cut Truss Tails (7:43 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      At the behest of some users who use this plugin for large agricultural buildings, I will be adding at couple more options for large trusses. Specifically a “Quad Howe” and a “Penta Howe” common truss option. The “Penta Howe” truss is suitable for trusses that measure up to 100’ in span (or greater). I had a little fun with this :slight_smile:
                      The barn I show with the tractor has a 92’ span truss with a 36" raised heel. Top and bottom chords are 2x8 with 2x6 webs. The trusses are double ply (3" width) and spaced at 4’ on center.
                      After I modeled this, I thought, what could a guy do with a garage like this? Okay, realistically I don’t need an aircraft hanger for a garage, but 36’x36’ sure would be nice.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.6.9 - 04.10.2025
                        • Enabled options for wood grain texture for lumber in the global settings.
                        • Enabled wood grain texture for common and scissor trusses.
                        • Added a Quad Howe and Penta Howe option for common trusses.
                        • Fixed a minor bug with 4/2 scissor trusses with raised heels.
                        • Fixed a minor bug with the bottom chord of certain common trusses.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.7.0 - 04.13.2025
                          • Enabled wood grain texture for the following truss types: attic, symmetric cathedral, cathedral, cambered, tail bearing, coffer, tray, and parallel chord.
                          • Added the following Parallel Chord truss type: 10/10.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.7.1 - 04.18.2025
                            • Enabled wood grain texture for the following truss types: flat.
                            • Added metal plates for all attic trusses.
                            • Added an attic furring option for attic trusses.
                            • Fixed a minor bug in the gable cut option for attic trusses.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.7.2 - 04.22.2025
                              • Enabled wood grain texture for the following truss types: gambrel attic, monopitch, monocathedral, monoscissor, polynesian, dual pitch, bowstring, bow barrel.
                              • Enabled wood grain texture for the following rafter roof types: gable, gable w/ glulam.
                              • Added the follow Monopitch truss type configuration: (4/4).
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.7.3 - 07.19.2025
                                • Enabled square cut rafter tails for gable rafter roofs.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.7.5 - 01.03.2026
                                  • Enabled hurricane ties for all remaining common trusses.
                                  • Enabled hurricane ties for scissor, cathedral, polynesian and dual pitch trusses.
                                  • Fixed a (metric) bug for the inset parameter for hurricane ties.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.7.6 - 01.07.2026
                                    • Added an offset parameter for coffer trusses (non-raised heel only).
                                    design.medeek.com
                                    • 75
                                    • 76
                                    • 2 / 76
