    Desired Space (3d Warehouse)
    8 Posts 3 Posters 407 Views 3 Watching
      I decided to take a look at the Desired Space items L i am has been rendering off and on.
      Not bad and simpler than I make scenes so good to test with.
      Worthy of mention is that there are two lightsources here, the top one is vissible but the lower item is absent from the render even if the light emited is present (I think).
      Rayscaper render.
      L 1 Reply Last reply Reply Quote 3
        L i am @Mike Amos
        @Mike-Amos Hi Mike niceπŸ‘ Does rayscaper have HDRI's
          Mike Amos @L i am
          @L-i-am
          Yes mate, HDRI and EXR formats.
            L i am @Mike Amos
            @Mike-Amos Did you use an HDRI in this pic?
            Mike AmosM 2 Replies Last reply Reply Quote 0
              @Mike-Amos Very nice result! Do you mind if I share the render on X as a showcase?
              Can you mail me the scene? I'm not clear where the second light source is supposed to be? It would be great if you could send me the image with a big circle on it where the missing light source goes.
              Cheers,
              Thomas
                Mike Amos @L i am
                @L-i-am
                I did use a HDRI, I can try to find out which one if you like.
                  Mike Amos @pixelcruncher
                  @pixelcruncher
                  The scene is available via the 3d warehouse via 'desired space'.
                  The second light source is below the one you see illumiated, in the lower of two wicker light shades.
                  Light settings are the same as the other, 1w and 1.25m radius. 4000k.
                  If you deem any of my renders suitable for promotion, go for it.
                  I accept gold bullion and uncut diamonds as remuneration.........
                  Lights more visible here?
                    Mike Amos @L i am
                    @L-i-am
                    Just checked HDRI, not present so I must have removed it or forgot to use it. Typical....
