    [Plugin] Axyz - v1.1a - 8 June 24
    51 Posts 14 Posters 8.5k Views 12 Watching
    • P
      PedroE @Rich O Brien
      @Rich-O-Brien Thank you for commenting, in my opinion it is interesting because with this possibility you could do without the native move command and thus you would have everything together in one command. This is very practical in the future to be able to work with a pencil without having to use the keyboard or for people who do not like to use the keyboard to draw. Anyway, thank you for your time and greetings
      • cengiziletenC
        cengizileten
        like Curic's gizmo.
          asdecret
          Hello everyone,
          I hope you are well.
          I am getting an trial licensed expired message for this extension.
          I thought this extension was free but maybe I am mistaken.
          When the error message appears when i try to purchase the license it goes to a dead web page.
          If anyone can give me some info I would greatly appreciate.
          have a nice day
            Rich O Brien Moderator @asdecret
            @asdecret
            What version of Libfredo are you using?
              asdecret
              Hello Rich,
              Thanks so much for the prompt reply, I apologize in the my late reply I thought my message had not gone through.
              I am using this LibFredo6 14.5f - 07 Aug 24.
              Thanks so much for your help and have a nice day.
              Alex
                asdecret
                Rich,
                Thanks so much
                I am using LibFredo6 14.5f - 07 Aug 24
                thanks
                  @asdecret said in [Plugin] Axyz - v1.1a - 8 June 24:
                  Rich,
                  Thanks so much
                  thanks
                  Upgrade your Libfredo please
                    asdecret
                    Hello Rich,
                    Thanks a million it worked like a charm.
                    Have a nice day
                    • panixiaP
                      panixia @rv1974
                      @rv1974 said in [Plugin] Axyz - v1.1a - 8 June 24:
                      @Rich-O-Brien Yes and no. without copying Select Instances+Axyz works fine.
                      Maybe you with(?) Fredo could develop a new rock solid version of "select all instances"?
                      BTW many people request "select all instances" that would copy all instances regardless the context to the memory buffer. the 20 y.o. one that I use can't do that.
                      Sorry for the late answer, but.. did you try Selection Toys?
                      Selecti a single instance, right click and in the context menu go to "instances" and then you can choose if you want select "all" (regardless the context) or "active" (all instances in the current context).
                      R 1 Reply Last reply
                        rv1974 @panixia
                        @panixia its a major PITA in SU: none of plugins copies all instances (incl. ones out of context) to memory buffer
                        panixiaP 1 Reply Last reply
                        • panixiaP
                          panixia @rv1974
                          @rv1974 with selection toys you can select all instances at once, included the ones outside the current context and then copy, cut, delete move or do whatever you wanna do.
                          Edit. I tried right now and it looks that with a lot of components scattered across different contexts, they are pasted using their original group local transform instead of world transform. Even if you use "paste on place". Weird.
                            rv1974 @panixia
                            @panixia you can select, take a look at their properties, replace and delete but not copy to buffer - it always been broken
                            • panixiaP
                              panixia @rv1974
                              @rv1974 i mainly use that feature to select all group copies and convert them to components (whenever I copy something around by mistake without making it a component to begin with). Never noticed that behaviour.. not sure if the glitch is related to the plugin. Most likely is some problem with SketchUp itself and how it natively handles sub-components local transform. The plugin is probably "bruteforcing" the intended SketchUp behaviour (which is working INSIDE the current context).
                                rv1974 @panixia
                                @panixia I got a Jim's plugin made by my request which he removed from public later..When all instances stay selected, it creates an outer txt file with coordinates and transforms, and in the 2nd stage the plugin inserts all instances into "no context" based on this txt file. A bit tedious but already something.. Sometimes I'm too lazy and just throw the file to Max where all contexts are gone
                                  rv1974
                                  @panixia curic true isolate + cleanup's delete hidden + undo do the trick
                                  • panixiaP
                                    panixia @rv1974
                                    @rv1974 I'll check.. I don't know the Curic true isolate plugin..
                                    • 3 / 3
