    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
    • G
      glenn bradley
      CleanUp3. I used the Extension Manager to install it. I did not re-install SU.
      I tried back-reving by zipping cleanup1, renaming it .rbz and using the Extension Manager to install it, no go; errors.
      I used Extension Manager to install CLeanUp3 again. It uses a pop-up to ask you to upgrade it which I do via the Extension Manager.
      I am still seeing the same 'edges reduced' figure despite repeated cleanings and saving of the file, closing re-opening the app, etc. The native 'statistics' do show a reduction the first time CleanUp3 is run so it is working. The repeated display of the original figures may just be a bug.
      I did find a bandsaw model that I have in a shop layout that reports a couple of hours to clean. Other similar models work fine. this bandsaw could be why my open and save functions on this particular file are slow, eh? πŸ˜‰
      I will let it run to completion and check the native stats and report back.
        What bandsaw component are you using?
          shannonnovus
          Repairing edges isn't working for me. It claims to remove edges, but it doesn't.
          For example, I'll select 12 connected edges.
          Run CleanUp3.
          The dialogue will say "Edges Reduced: 3".
          But all 12 original edges remain.
          So it's like CleanUp3 sees the correct edges that it should be deleting, but then it doesn't actually delete them.
          I'm running SketchUp 2020 on Windows, with CleanUp3 v3.4.3.
          I'd appreciate any suggestions.
          Thanks for all the great plugins, thomthom.
          • istavangI
            istavang
            @thomthom said:
            @ecuadorian said:
            Thank you, man. I have the perfect file to test it. πŸ˜„
            A particular troublesome file? Please let me know how it goes. Not sure if I've got it fully tuned in yet.
            Hei hva med en shortcut icon in toolbar ?
            Thanks Dan
            Stavanger
            • istavangI
              istavang
              Can you add a stop clean button ? , coz when removing dublicated faces takes hours on large components
              Thanks Dan
              • istavangI
                istavang
                Opps my bad , there is a cancel button when u dont use last settings sorry
                great cleaner
                Dan
                  RexGoodheart
                  @bionic58 said:
                  I wanted a toolbar icon to run "Clean with last settings" without having to go to navigate down the plugins menu, so I added the following code to core.rb under the ### MENU & TOOLBARS ### section:
                  What version of SketchUp? In Sketchup2019 I've looked for a core.rb file and can't find it. I would really like such a toolbar, and am wondering why a Cleanup3 toolbar was not included with installation?
                    Why a toolbar isn't included? Maybe the author didn't think a toolbar was important enough to invest time in, especially when he's made it available at no charge. I just set up a keyboard shortcut for it instead of using valuable screen real estate. That works just fine for me.
                    @rexgoodheart said:
                    In Sketchup2019...
                    Please update your profile. It says you're still using SU2016 Make.
                    • K
                      KhaledCole
                      How to configure this plugin so that after cleaning the edges are displayed as on the right cube? (On two different PCs, this plug-in is configured the same way. However, after cleaning, on one cube as on the left (visually as before cleaning), and on the other as on the right...). Thank you!
                      https://i.ibb.co/Kmbm0hr/Untitled.jpg
                        matveymatveev
                        @thomthom
                        Hello, Thom!
                        Are you planing to update the plugin so it can use more (or all) of the computing capacity?
                        • 45
                        • 46
                        • 47
                        • 48
                        • 49
                        • 49 / 49
