    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      glenn bradley
      I am seeing the CleanUp stats unchanged when running it more than once on the same thing as well. Make 2017 on Win 10. I uninstalled the Lib and the CleanUp extension. Being Windows I rebooted and did a fresh install. CleanUp now reports hours to completion on tasks that took seconds before.
      I did another purge and reinstall with fresh downloads, results are the same so there may be a problem with older versions although the notes state compatibility. I will back-rev and report back.
        CleanUp or CleanUp3
        When you did the reinstall was that for SketchUp? If so, did you right click on the installer and choose Run as administrator?
          glenn bradley
          Not quite 2 hours to complete. The native stats show a small decrease in edges and faces for the bandsaw model. When I run CleanUp3 again the same figures appear and the nearly 2 hour estimate re-starts.
          I'm not sure where to go from here as I stubbornly stick with Make 2017. I will try the built in purge and fix functions and see how I get on. I cannot say that this behavior is universal as I only have my current Win 10 and Make 2017 environment.
            glenn bradley
            CleanUp3. I used the Extension Manager to install it. I did not re-install SU.
            I tried back-reving by zipping cleanup1, renaming it .rbz and using the Extension Manager to install it, no go; errors.
            I used Extension Manager to install CLeanUp3 again. It uses a pop-up to ask you to upgrade it which I do via the Extension Manager.
            I am still seeing the same 'edges reduced' figure despite repeated cleanings and saving of the file, closing re-opening the app, etc. The native 'statistics' do show a reduction the first time CleanUp3 is run so it is working. The repeated display of the original figures may just be a bug.
            I did find a bandsaw model that I have in a shop layout that reports a couple of hours to clean. Other similar models work fine. this bandsaw could be why my open and save functions on this particular file are slow, eh? πŸ˜‰
            I will let it run to completion and check the native stats and report back.
              What bandsaw component are you using?
                shannonnovus
                Repairing edges isn't working for me. It claims to remove edges, but it doesn't.
                For example, I'll select 12 connected edges.
                Run CleanUp3.
                The dialogue will say "Edges Reduced: 3".
                But all 12 original edges remain.
                So it's like CleanUp3 sees the correct edges that it should be deleting, but then it doesn't actually delete them.
                I'm running SketchUp 2020 on Windows, with CleanUp3 v3.4.3.
                I'd appreciate any suggestions.
                Thanks for all the great plugins, thomthom.
                • istavangI Offline
                  istavang
                  @thomthom said:
                  @ecuadorian said:
                  Thank you, man. I have the perfect file to test it. πŸ˜„
                  A particular troublesome file? Please let me know how it goes. Not sure if I've got it fully tuned in yet.
                  Hei hva med en shortcut icon in toolbar ?
                  Thanks Dan
                  Stavanger
                  • istavangI Offline
                    istavang
                    Can you add a stop clean button ? , coz when removing dublicated faces takes hours on large components
                    Thanks Dan
                    • istavangI Offline
                      istavang
                      Opps my bad , there is a cancel button when u dont use last settings sorry
                      great cleaner
                      Dan
                        RexGoodheart
                        @bionic58 said:
                        I wanted a toolbar icon to run "Clean with last settings" without having to go to navigate down the plugins menu, so I added the following code to core.rb under the ### MENU & TOOLBARS ### section:
                        What version of SketchUp? In Sketchup2019 I've looked for a core.rb file and can't find it. I would really like such a toolbar, and am wondering why a Cleanup3 toolbar was not included with installation?
                          Why a toolbar isn't included? Maybe the author didn't think a toolbar was important enough to invest time in, especially when he's made it available at no charge. I just set up a keyboard shortcut for it instead of using valuable screen real estate. That works just fine for me.
                          @rexgoodheart said:
                          In Sketchup2019...
                          Please update your profile. It says you're still using SU2016 Make.
                            KhaledCole
                            How to configure this plugin so that after cleaning the edges are displayed as on the right cube? (On two different PCs, this plug-in is configured the same way. However, after cleaning, on one cube as on the left (visually as before cleaning), and on the other as on the right...). Thank you!
                            https://i.ibb.co/Kmbm0hr/Untitled.jpg
                              matveymatveev
                              @thomthom
                              Hello, Thom!
                              Are you planing to update the plugin so it can use more (or all) of the computing capacity?
                              • 45
                              • 46
                              • 47
                              • 48
                              • 49
                              • 49 / 49
