    Medeek Floor
    152 Posts 6 Posters 44.9k Views 5 Watching
    • medeekM Offline
      medeek
      Version 0.9.6 - 09.19.2024
      • Fixed a bug with metric floor presets.
      • Fixed a bug with the insulation module.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I am changing up the way in which I do subtractive geometry from the way I've done it with the other plugins in the past.
        If you enable Subtractive Geometry in the global settings you can use the SUBTRACT keyword to cut holes through everything as per normal. However you will now also have two other options:
        SUBTRACT_SHEATH: This keyword will only subtract through sheathing, flooring and deck boards.
        SUBTRACT_GYPSUM: This keyword will only subtract through gypsum
        I may add others as the need arises or additional requests are made.
        design.medeek.com
        • medeekM Offline
          medeek
          Adding in the advanced floor options into the Global Settings:
          I am working on adding in metal bridging with some associated parameters:
          P.S.
          I was going to combine the metal bridging with the solid blocking however after some thought I realized there might be cases where you might combine both forms of bracing in one floor (solid blocking and metal bridging). Hence I need a separate module for blocking. Unlike the wall blocking floor blocking may be regular lumber or I-Joist blocking so that further complicates the matter slightly.
          The parameters for the blocking module will probably be:
          1.) Blocking Type: Lumber/I-Joist
          If blocking type is Lumber:
          Blocking Width: 1.5 in (default)
          Blocking Material: Lumber / PT Lumber / LSL / PSL / LVL etc...
          If blocking type is I-Joist
          Blocking I-Joist Family:
          Blocking I-Joist Type:
          other general parameters are:
          Row Spacing: 96 in. (default)
          Stagger Blocking: Yes/No
          Remove Row: empty by default
          Quite a few more parameters (8) to add into a number of files, this will keep me busy for a couple of days at least.
          design.medeek.com
          • medeekM Offline
            medeek
            First look at metal bridging (I-joist and Lumber):
            Geometrically a lot simpler and more lightweight than the preconfigured component that I made based off of the Simpson IFC model. I'm using my galvanized texture/material but I may change it slightly. There are quite a few parameters that one can adjust to customize the look and feel of these metal bridging straps, hopefully that should make things configurable enough for most power users.
            As noted per the Simpson literature the crossing straps should not be in direct contact to avoid screeching noises when they move under load. Hence the default 1/8" gap, but this can be modified as can be seen in the menu.
            I've also included a thickness parameter for the straps. The correct thickness for a 20 gauge strap is probably around 0.035" however I've rounded the default value to an even 0.04".
            design.medeek.com
            • medeekM Offline
              medeek
              Version 0.9.7 - 09.23.2024
              • Updated the SUBTRACT feature with three other options.
              • Added seven advanced options in the Floor tab of the Global Settings.
              • Added metal bridging to the Draw and Edit menus.
              • Added solid blocking (Lumber and I-Joist) to the Draw and Edit menus.
              • Fixed minor bugs in the HTML menus and preset system.
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 3 - Metal Bridging and Blocking (10:28 min.)
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 0.9.8 - 09.27.2024
                  • Made the polyline/face icon (draw mode) in the draw menu clickable.
                  • Added a joist direction toggle button/icon to the draw and edit menus.
                  • Added a stagger joist option to the Draw and Edit menus.
                  • Updated the insulation, blocking, metal bridging and hanger modules to accommodate staggered joists.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    So yes, staggered joist present a few issues. For example if the blocking doesn't land in the lapped region of the joist layout you end up with this:
                    Right at the moment I'm not sure how to address this or actually determine when the blocking lands in the non-lapped sections of the layout. The easy way out would be to do a boolean subtraction using the joists themselves, but then I would need to separate the resulting (multi-body) group into a bunch of groups/solids, this one is a bit of headache.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      With staggered joists I am tracking how many rows of joists I need, the joist length and lapped length, so given that information (three variables) I can then run a quick check on each blocking row to see how it pencils out. This little block of code does the trick:
                      if @Spanno < 2
                      			stoffset = 'NEG'
                      		else
                      			lapcount = 1
                      			for lapi in @Stjarray
                      				if (distx > lapi[0]) && (distx < lapi[1])
                      					stoffset = 'LAP'
                      					break
                      				elsif distx < lapi[0]
                      					if lapcount.odd?
                      						stoffset = 'NEG'
                      					else
                      						stoffset = 'POS'
                      					break
                      				elsif (distx > lapi[1]) && (lapcount == (@Spanno - 1))
                      					if lapcount.odd?
                      						stoffset = 'POS'
                      					else
                      						stoffset = 'NEG'
                      					break
                      				lapcount = lapcount + 1
                      As one can see there are really only three possibilities for the blocking: Lapped, Positive or Negative.
                      The end result is this:
                      Problem solved. Now I just need to apply this same logic to the metal bracing and implement it. Insulation is somewhat different so I still don’t have a good solution for that one just yet.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        After another three hours of some productive thought and hacking away at some rather large blocks of code (and a few choice words) I managed to pull together a fairly efficient and robust algorithm for the cavity insulation between those irregular joists.
                        Ladies and Gentlemen, I give you “Batt Insulation with Staggered Joists”:
                        I’m exhausted, tomorrow I might take a small break.
                        design.medeek.com
                        gullfoG 1 Reply Last reply Reply Quote 1
                        • gullfoG Offline
                          gullfo @medeek
                          what if i want them staggered the other way? LOL J.K. nicely done!
                          Glenn
                          http://www.runnel.com
                          • medeekM Offline
                            medeek
                            First look at skewed hangers with staggered joists:
                            A little bit more complicated than regular joists due to the offsets but overall its pretty much the same routine. Pretty excited that I actually can get this to work, at first I wasn't really sure if it was even feasible.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 0.9.9 - 10.01.2024
                              • Further updated the insulation, blocking, metal bridging and hanger modules to accommodate staggered joists.
                              • Added skewed hanger options into the Floor tab of the Global Settings.
                              • Added skewed hangers to the Draw and Edit menus.
                              • Added the following skewed (45 degree) Simpson hangers into the built-in library: SUL24, SUL26, SUL210, SUL214, SUL1819, SUL18111, SUL18114, SUL2069, SUL20611, SUL20614, SUR24, SUR26, SUR210, SUR214, SUR1819, SUR18111, SUR18114, SUR2069, SUR20611, SUR20614
                              • Updated and added a new subtraction mode to the SUBTRACT feature: SUBTRACT_JOIST
                              • Added Subtractive Geometry (Joist) in the General tab of the Global Settings.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 0.9.9b - 10.01.2024
                                • Updated the Floor tab of the Global Settings with additional parameters for joist construction.
                                • Fixed a minor bug with the hanger module for double ply staggered studs.
                                • Fixed a bug in the Draw and Edit menus so that all hangers in the library are properly displayed.
                                • Added the following skewed (45 degree) Simpson hangers into the built-in library (skew_hangers): SUL410, SUL414, SUL214_2, SUL210_2, SUL26_2, SUR410, SUR414, SUR214_2, SUR210_2, SUR26_2
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 0.9.9c - 10.03.2024
                                  • Enabled diagonal deck boards with the addition of a Board rotation parameter.
                                  • Enabled 2-Ply rim joists with our without an air gap.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 0.9.9d - 10.03.2024
                                    • Fixed critical bugs with saving of floor presets.
                                    • Improved robustness of floor attribute library and data lookup methods.
                                    Some incremental improvements but necessary.
                                    IMPORTANT
                                    Note that the last few updates prior to this update introduced a number of new features that effectively disabled the saving of floor presets. Please download this latest update to restore the ability to save floor presets.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Double rim joists with air gap, lapped and extended:
                                      A quick test of the non-orthogonal floor types shows that the algorithm holds up as it should:
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.9.9e - 10.04.2024
                                        • Updated 2-Ply rim joists with air gap to extend joists that are in a lapped configuration.
                                        • Updated the Floor tab of the Global Settings with even more parameters for joist construction.
                                        • Added the following face mount Simpson hangers into the built-in library: MIU1819, MIU18111, MIU18114, MIU18116, MIU18118.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Tutorial #4: Deck Boards (6:42 min.)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Tutorial 5 - Rim Joists and Sill Plates (5:47 min.)
                                            design.medeek.com
                                            • 3 / 8
