    Tool like Profile Builder but for duplicating an object across another surface?
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    5 Posts 3 Posters 378 Views 3 Watching
      DickWolf
      Hi guys, is there an extension that could duplicate an object (like the red square) across another face to cover the whole face. Maybe in a similar manner as grid tool? I want to do this to speed up workflow with 3D roof tiles, by covering the roof with the roof tile object and then trimming the overlap with something like trim tools.
      Best Regards
      R Gus RG 2 Replies Last reply Reply Quote 0
      • Gus RG Offline
        Gus R @Gus R
        @Gus-R I think this is "solved."
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
          rv1974 @DickWolf
          @DickWolf in SU - Vray Enmesh
          • Gus RG Offline
            Gus R @DickWolf
            @DickWolf Try Comps to Grid in JHS Powerbar. I never used it but found it this morning. Seems to work best with the component's axis set at the bottom and the center of mass.
            Doesn't work when the face is inside a group
            Watch this video too. It's a visual explanation around the middle of the video.
            Gus RG D 2 Replies Last reply Reply Quote 1
            • Gus RG Offline
              Gus R @Gus R
                DickWolf @Gus R
                @Gus-R Thank you very much! This looks like exactly what i need.
