    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
    • medeekM
      medeek
      Version 1.9.2 - 11.30.2023
      • Enabled Openings for stemwall steps: Windows and Doors.
      • Enabled Blockouts for stemwall steps.
      http://design.medeek.com/resources/foundationplugin/images3/foundation_su122_800.jpg
      This update per customer request. Now openings and blockouts can be used in either polyline stemwalls or stemwall steps.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.9.3 - 12.16.2023
        • Fixed a bug with drain pipes for polyline stemwall foundations which have openings or blockouts enabled.
        design.medeek.com
        • medeekM
          medeek
          Version 1.9.4 - 01.07.2024
          • Updated and improved the license verification module.
          • Disabled redundant logging to improve plugin performance.
          design.medeek.com
          • medeekM
            medeek
            Version 1.9.5 - 02.13.2024
            • Improved the serial number verification logic within the License tab of the Global Settings.
            • Updated the javascript logic within the License tab of the Global Settings.
            • Added statistics for the following foundation types (Medeek Estimator integration): Slab-on-Grade, Slab, Stemwall, Grade Beam
            design.medeek.com
            • medeekM
              medeek
              Version 1.9.6 - 04.20.2024
              • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
              design.medeek.com
              • medeekM
                medeek
                Version 1.9.7 - 04.23.2024
                • Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
                design.medeek.com
                Reply Quote 2
                • medeekM
                  medeek
                  [b]Version 1.9.8[/b] - 04.28.2024
                  • Updated the license verification system with a more secure and improved algorithm.
                  • Updated the polyline stemwall tool with an improved wireframe preview which includes the footing.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.9.9 - 06.06.2024
                    • Added additional rebar sizes for slab reinforcement for slab and SOG foundations: #6, #7, #8, #9, #10, #11, #14, #18.
                    http://design.medeek.com/resources/foundationplugin/images3/foundation_su127_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.0.0 - 06.27.2024
                      • Fixed a bug in the rebar module for stemwall step assemblies.
                      • Added the following Simpson column bases to the built-in library: CPT44Z, CPT66Z, CPT88Z
                      foundation_su128_800.jpg http://design.medeek.com/resources/foundationplugin/images3/foundation_su128_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.0.1 - 08.01.2024
                        • Added a duplicate foundation assembly check to the regen module for the following foundation types: Stemwall, SOG, Slab, Stemwall Step, Grade Beam, Strip Footing, Footing.
                        The instructions for usage are the same as the recent update to the Wall plugin, see Wall Plugin Tutorial #51:
                        design.medeek.com
                        Reply Quote 2
                        • medeekM
                          medeek
                          Version 2.0.2 - 08.07.2024
                          • Fixed a bug in the wireframe preview for polyline stemwalls.
                          • Fixed a bug with horizontal rebar for polyline stemwall foundations (closed, RIGHT direction).
                          • Added the stemwall "Hide Edges" parameter to the General tab of the Global Settings.
                          design.medeek.com
                          • medeekM
                            medeek
                            Tutorial 13 - Framing Basement Walls (15:17 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.0.3 - 03.23.2025
                              • Enabled removal of individual anchor bolts for (polyline) stemwall and slab-on-grade foundations.
                              • Enabled addition of custom location anchor bolts for (polyline) stemwall and slab-on-grade foundations.
                              design.medeek.com
                              • medeekM
                                medeek
                                Tutorial 14 - Managing Anchor Bolts (12:13 min.)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 2.0.4 - 03.27.2025
                                  • Enabled removal of individual anchor bolts for stemwall step foundations.
                                  • Enabled addition of custom location anchor bolts for stemwall step foundations.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.0.7 - 02.05.2026
                                    • Fixed a bug with the (double) stemwall step when the ICF option is active.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Tutorial 15 - Multi-Step Foundations (8:24 min.)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 2.0.8 - 03.01.2026
                                        • Updated the SOG draw tool with a more robust "face" draw option.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 2.0.8b - 03.02.2026
                                          • Updated the Slab draw tool with a more robust "face" draw option.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.0.9 - 03.03.2026
                                            • Added a "Separate Callouts" option for stemwall foundations into the General tab of the Global Settings.
                                            • Separate callouts for stemwall foundations display the volume for footing and stemwall portions independently.
                                            design.medeek.com
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
