    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
    • medeekM
      medeek
      Tutorial 12 - Grade Beams (9:38 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        So I drew this with the column and new grade beam module:
        https://aws1.discourse-cdn.com/sketchup/original/3X/e/2/e24c8269689df9c916cbaecb3597d89f32de5fa1.jpeg
        My oldest son then asked me, "What is it?"
        My answer was, "I don't know, it's whatever you want it to be."
        design.medeek.com
        • medeekM
          medeek
          I have begun posting older versions of the Foundation plugin for download but I would strongly encourage users to download and use the latest version of the plugin since I do not support older versions, especially if they are older than a year old. The number of bug fixes and feature additions make it very hard for me to keep track of which version addressed which issue. If you need support please make sure you have the latest version of the extension installed.
          404 - File or directory not found.
          (design.medeek.com)
          (design.medeek.com)
          design.medeek.com
          • medeekM
            medeek
            Version 1.8.7 - 07.31.2022
            • Added slab depressions for rectangular and polygon slab assemblies.
            • Enabled editing, moving and deleting of slab depressions for all slab assemblies.
            • Added a "Regen" context menu item for polygon slab on grade (SOG) and slab assemblies.
            http://design.medeek.com/resources/foundationplugin/images3/foundation_su117_800.jpg
            design.medeek.com
            • medeekM
              medeek
              Version 1.8.8 - 07.31.2022
              • Added a "Regen" context menu item for column footings and stemwall step assemblies.
              • Added the ability to customize the texture/material for stemwall foundations.
              • Added a "Stemwall Texture" parameter into the Materials tab of the global settings.
              http://design.medeek.com/resources/foundationplugin/images3/foundation_su118_800.jpg
              http://design.medeek.com/resources/foundationplugin/images3/foundation_su119_800.jpg
              http://design.medeek.com/resources/foundationplugin/images3/foundation_su120_800.jpg
              The "4x8 form" texture option was per customer request.
              design.medeek.com
              • medeekM
                medeek
                !!!! BUG ALERT - SKETCHUP 2023 !!!!
                I've just identified an issue with the Foundation plugin and the current release of SU 2023.
                Many of the tools within the Truss plugin still use the UI.inputbox module for simple menus, see example below:
                https://global.discourse-cdn.com/sketchup/original/3X/a/b/ab1923aa13e5f1d3fef95de34704e24cd0acdaf0.jpeg
                If you notice that this type of menu appears (not an HTML menu) then press Alt-Tab which will then require you to refocus on the menu with your mouse and will also allow it to function correctly (unfreezes the menu).
                I don't know all of the details however it appears that the backend framework has extensively changed and in the process a few focus bugs have slipped through and need to be ironed out with SU 2023. See status and more details at the thread below:
                SketchUp 2023 - changes to UI.inputbox focus?
                Question for the proper coders: A case of three ruby plugins; a plugin with a floating quad menu with my most-used commands - pressing items launches other plugins. a plugin that directly launches a UI.inputbox a plug…
                SketchUp Community (forums.sketchup.com)
                For now I would recommend staying with SU 2022 if you extensively use SketchUp combined with the Truss and Foundation plugins. However the alt-tab work around should also keep you up and running if you have already migrated to SU 2023.
                I am hoping that minor update will be forthcoming in the near future from SketchUp, which will save me from having to rewrite a significant amount of code and pull me away from the Floor plugin development. If the bug is not fixed I will proceed to switch all remaining menus in the Truss and Foundation plugins to HTML dialog type menus, that process could take upwards of two to three weeks.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.9.0 - 07.11.2023
                  • Fixed a minor bug with the "Edit Outline" menus for various foundation types.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.9.1 - 09.26.2022
                    • Added a negative X and negative Y slope direction for slab depressions.
                    http://design.medeek.com/resources/foundationplugin/images3/foundation_su121_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.9.2 - 11.30.2023
                      • Enabled Openings for stemwall steps: Windows and Doors.
                      • Enabled Blockouts for stemwall steps.
                      http://design.medeek.com/resources/foundationplugin/images3/foundation_su122_800.jpg
                      This update per customer request. Now openings and blockouts can be used in either polyline stemwalls or stemwall steps.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.9.3 - 12.16.2023
                        • Fixed a bug with drain pipes for polyline stemwall foundations which have openings or blockouts enabled.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.9.4 - 01.07.2024
                          • Updated and improved the license verification module.
                          • Disabled redundant logging to improve plugin performance.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.9.5 - 02.13.2024
                            • Improved the serial number verification logic within the License tab of the Global Settings.
                            • Updated the javascript logic within the License tab of the Global Settings.
                            • Added statistics for the following foundation types (Medeek Estimator integration): Slab-on-Grade, Slab, Stemwall, Grade Beam
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.9.6 - 04.20.2024
                              • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.9.7 - 04.23.2024
                                • Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
                                design.medeek.com
                                Reply Quote 2
                                • medeekM
                                  medeek
                                  [b]Version 1.9.8[/b] - 04.28.2024
                                  • Updated the license verification system with a more secure and improved algorithm.
                                  • Updated the polyline stemwall tool with an improved wireframe preview which includes the footing.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.9.9 - 06.06.2024
                                    • Added additional rebar sizes for slab reinforcement for slab and SOG foundations: #6, #7, #8, #9, #10, #11, #14, #18.
                                    http://design.medeek.com/resources/foundationplugin/images3/foundation_su127_800.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.0.0 - 06.27.2024
                                      • Fixed a bug in the rebar module for stemwall step assemblies.
                                      • Added the following Simpson column bases to the built-in library: CPT44Z, CPT66Z, CPT88Z
                                      foundation_su128_800.jpg http://design.medeek.com/resources/foundationplugin/images3/foundation_su128_800.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 2.0.1 - 08.01.2024
                                        • Added a duplicate foundation assembly check to the regen module for the following foundation types: Stemwall, SOG, Slab, Stemwall Step, Grade Beam, Strip Footing, Footing.
                                        The instructions for usage are the same as the recent update to the Wall plugin, see Wall Plugin Tutorial #51:
                                        design.medeek.com
                                        Reply Quote 2
                                        • medeekM
                                          medeek
                                          Version 2.0.2 - 08.07.2024
                                          • Fixed a bug in the wireframe preview for polyline stemwalls.
                                          • Fixed a bug with horizontal rebar for polyline stemwall foundations (closed, RIGHT direction).
                                          • Added the stemwall "Hide Edges" parameter to the General tab of the Global Settings.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Tutorial 13 - Framing Basement Walls (15:17 min.)
                                            design.medeek.com
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
