    Open areas and rounded surface
    31 Posts 3 Posters 3.7k Views 3 Watching
      Dave R @Alohaa
      @Alohaa I think @Box has put his finger on it. You must be opening the wrong file. As you can see in his GIF as well as in my screen shots, my version with the section cut and your original model in the background are present.
      A 1 Reply Last reply
        Alohaa @Dave R
        Sorry, but there was only 1 file attached here, from you 2 days ago, and you removed it, I assume, because it is no longer in your post.
        The file I downloaded, 2 times, hence the number 2 after the name (which also indicates that it is the downloaded file), contains only my drawings, unlike the one shown by @Box in the gif posted earlier. And he (or she) didn't post an SU file!
        Am I crazy or am I right?
        Update: I have found the file below the image, of which I first thought it was the name.
        So, everything is fine! Sorry
        Dave RD BoxB 2 Replies Last reply
          Dave R @Alohaa
          @Alohaa said in Open areas and rounded surface:
          I did not remove the file. It is still there immediately under the screenshot. How do you think Box was able to open my file?
          I made it more clear in that post.
          There was no reason for him to share the file since it's the same as the one in my post.
          Sorry. Of those two choices, I'd have to say you're crazy.
            Alohaa @Dave R
            @Dave-R Let's say, I was crazy, until I opened the eyes.
            How can I remove the sectioning? I have never used this function (like many others!).
            Dave RD 1 Reply Last reply
              Dave R @Alohaa
              @Dave-R
              Select the section plane and press Delete.
              • BoxB
                Box @Alohaa
                You've asked this twice in this thread alone. In this case you aren't 'right'.
                  Alohaa @Box
                  @Box I am reassured to read I would not be right to be crazy 😉
                    Alohaa
                    What I still don't know: how can I guide the rounding on the lid around the corner?
                      Dave R @Alohaa
                      @Alohaa what are you referring to now? What lid? What rounding?
                        Alohaa
                        The rounding that can be seen in my first post and that I only managed to draw until the corner.
                        BoxB 1 Reply Last reply
                        • BoxB
                          Box @Alohaa
                          @Alohaa Create a suitable profile and use follow me.
                            Alohaa
                            ok, I understand the principle.
                            What I have some difficulties to understand is the method how you fill the surface.
                              Dave R @Alohaa
                              @Alohaa Box double clicked on the surface of the large hole which selected the surface and its edges. Then he pressed Delete. The hole was automatically filled in.
                              • BoxB
                                Box @Dave R
                                @Dave-R said in Open areas and rounded surface:
                                @Alohaa
                                How about the button to the right of the Image Upload button?
                                Here is a link to were it first became apparent to me.
                                Dave has an upload button and we don't.
                                  Alohaa
                                  Why, is the exciting question!
                                    Alohaa
                                    Isn't there an explanation for this strange fact?
                                      Alohaa @Alohaa
                                      obviously not. mysterious!
                                      • 2 / 2
