    [Plugin] Rotate 90 around [X, Y, Z] axis
    49 Posts 28 Posters 65.5k Views 28 Watching
      Mainline411
      @glro said:
      @hfm said:
      okay, very nice script... but could you please also make it work on X and Y axis? And make it so that you can select a shortcut for the tools?
      Tried to edit it myself but my knowledge of ruby is lacking 🀣
      [did get the 15 degrees to work though πŸ˜„ ]
      I don't know much about ruby either, but here is a simplified version of the plugin:
      rotate around the component origin instead of center
      only around z axis and 90 degrees
      no context menu, a line in the plugin menu instead (so you can add a keyboard shortcut (pop up menu, window>preferences>shortcut
      require 'sketchup.rb'
      > ## Rotate selected component instance 90 degrees around Z axis
      > ##  Copyright (c) 2010 Clark Bremer (aka daiku)
      > ##  Northern Lights Timber Framing
      > ##  clarkb@northernlightstimberframing.com
      > ## 05/02/12; rotation autour de l'origine du composant, axe z seulement, acces menu deroulant ou raccourci clavier
      > ## 9/10/2010;	Multiple Groups/Comps
      > ## 5/17/08;  All 3 axes.  Input from Matt666
      > ## 4/24/08; Use center as rotation point instead of CI origin.  Also works on groups now.
      > # Add a menu item to launch our plugin.
      > UI.menu("PlugIns").add_item("rotation90z") { rotate90z }
      >  def selected_comps_and_groups
      >      mm = Sketchup.active_model
      >      ss = mm.selection
      >  	return nil if ss.empty?
      >  	ss.each do |cc|
      >  		return nil if not ((cc.instance_of? Sketchup;;ComponentInstance) or (cc.instance_of? Sketchup;;Group))
      >  	end
      >     ss
      >  end
      > #def rotate90(sel, axis)
      > def rotate90z
      > 	sel = selected_comps_and_groups
      > #	axis == "z"
      > 	rv = Geom;;Vector3d.new(0,0,1)
      > #	rv = Geom;;Vector3d.new(0,0,1) if axis == "z"
      > #	rv = Geom;;Vector3d.new(0,1,0) if axis == "y"
      > #	rv = Geom;;Vector3d.new(1,0,0) if axis == "x"
      > 	ra = 90.degrees
      > 	#rt = Geom;;Transformation.rotation(rp, rv, ra) #autour du centre de la boite enveloppe
      > 	sel.each do |ent|
      > 		# rp = Geom;;Point3d.new(ent.bounds.center) 		#rotation point
      > 		rp = Geom;;Point3d.new(ent.transformation.origin)
      > 		ent.transform!(Geom;;Transformation.rotation(rp, rv, ra))
      > 	end
      > end
      > #if( not file_loaded?("rot90.rb") )
      > #   UI.add_context_menu_handler do |menu|
      > #		if menu == nil then
      > #			UI.messagebox("Error setting context menu handler")
      > #		else
      > #			if (sel = selected_comps_and_groups)
      > #				sbm = menu.add_submenu("Rotate 90")
      > #				sbm.add_item("Around Red") {rotate90 sel, "x"}
      > #				sbm.add_item("Around Green") {rotate90 sel, "y"}
      > #				sbm.add_item("Around Blue") {rotate90 sel, "z"}
      > #			end
      > #		end
      > #	end
      > #end
      > #file_loaded("rot90.rb")
      How do I use this plugin I put the file in plugins and there is nothing in plugins dropdown and nothing when I right click.
        d12dozr
        Great plugin when mapped to a shortcut. Thanks Clark!
        FYI everybody, Clark just headed up a local meetup about ruby programming. πŸŽ‰
        http://goo.gl/f7ooYh
        • W
          waltersalter
          Sorry, does anyone know hot to use this very useful plugin in SketchUp2016? I tried just putting it with other rb files in rooth folder, but it didn't work. Help please!
          • K
            Kmyklpenter
            Hello! Thanks for the plugin! For some reason Im having problem assigning a keybouard shortcut for certain actions. The plugin does not appear in shortcuts list.
            How can I do that?
            Thank you.
              Do you have a group or component selected in the model? Like other Context menu items, you need to have something selected that would make this plugin appear in the menu.
              • O
                oman3000
                hello im a fan of this extension. simple yet useful. im just hope it to rotate even ungroup entities for the next version update. πŸ˜„
                • V
                  Vizan
                  How to make only the axis of a component or a group rotate?
                  • T
                    tubkanobaka
                    Great plugin, thanks a lot πŸ€“
                    • F
                      freestylerboo
                      This Plugin is the bomb.. such a simple task, but mapped to shortcuts is so powerful. i use this everyday and would be genuinely lost without it. Thankyou!!
                        Rich O Brien Moderator @freestylerboo
                        @freestylerboo said in [Plugin] Rotate 90 around [X, Y, Z] axis:
                        Imagine if there was a tool handled rotation, translation and scaling.....
                        V 1 Reply Last reply
                        • V
                          Vizan @Rich O Brien
                          @Rich-O-Brien said in [Plugin] Rotate 90 around [X, Y, Z] axis:
                          This looks great!
                          • 3 / 3
