3D Truss Models
Version 3.3.4- 10.01.2023
- Added a "Complex Roof" tab to the Global Settings.
- Added a "Roof Framing" and "Advanced Options" parameter to the Complex Roof tab of the Global Settings.
- Added a "Primitive" option to the roof framing parameter within the Draw and Edit menus for complex roofs.
- Enabled the Up Arrow key as a method to toggle between "face" or "polygon" mode within the complex roof draw tool.
Tutorial 26: Complex Roof Primitives (6:42 min.)
Version 3.3.4b - 10.02.2023
- Added a "Draw Mode" parameter to the Complex Roof tab of the Global Settings.
- Enabled a vertex (roof plane) selection method within the face selection algorithm of the Draw tool for complex roofs.
Tutorial 27: Drawing Complex Roofs (6:01 min.)
Version 3.3.5 - 10.06.2023
- Sheathing Vertical Offset parameters added for common and monopitch trusses.
- Cladding Vertical Offset parameters added for common and monopitch trusses.
By customer request.
This feature is already implemented within the Wall plugin so it is about time that I bring the Truss plugin up to speed as well. I think these four parameters are self explanatory enough that I don't need a tutorial video but if I do please let me know.
I still need to come up with a good porch module for wrap around porches and the like, but in the meantime with some careful use of the SUBTRACT function one can get pretty close:
The model can be viewed here:
https://3dwarehouse.sketchup.com/model/64c6616c-bbfb-4323-98da-e6c60fa3a522/Wrap-Around-Porch
Version 3.3.7 - 10.29.2023
- Enabled the "Edit Truss Assembly" function for symmetric cathedral trusses (imperial and metric units).
- Added ceiling gypsum for symmetric cathedral trusses.
- Fixed a minor bug with parellel chord trusses.
Version 3.3.9 - 12.30.2023
- Updated and improved the license verification module.
- Disabled redundant logging to improve plugin performance.
Version 3.4.0 - 01.11.2024
- Added a "Primitive" option to the roof framing parameter within the Draw and Edit menus for the following rafter roofs: Gable, Shed, Shed (with ledger), Hip.
- Added lower pitches to the draw menus for the following rafter roofs: Gable, Shed, Shed (with ledger), Hip.
Version 3.4.1 - 04.18.2024
- Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
Version 3.4.2 - 04.23.2024
- Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
Version 3.4.3 - 04.30.2024
- Added ceiling gypsum for tray and coffer trusses.
- Enabled the "Edit Truss Assembly" function for tray and coffer trusses (imperial and metric units).
- Enabled labels for tray and coffer trusses.
- Updated the license verification system with a more secure and improved algorithm.
[b]Version 3.4.4[/b] - 05.02.2024
- Added ceiling gypsum for cambered and mono cathedral trusses.
- Enabled the “Edit Truss Assembly” function for cambered and mono cathedral trusses (imperial and metric units).
- Enabled labels for cambered and mono cathedral trusses.
- Fixed some minor bugs for mono cathedral trusses.
Version 3.4.5 - 05.10.2024
- Enabled ceiling insulation for shed rafter roofs: Batt, Blown-in.
- Enabled ceiling insulation for gable rafter roofs: Batt, Blown-in.
- Enabled ceiling insulation for hip rafter roofs: Batt, Blown-in.
- Enabled the "Edit Truss Assembly" function for all flat trusses (imperial and metric units).
@medeek -- no spray foam? actually, probably changing the material on the rafter insulation (first image) would probably represent.
Version 3.4.6 - 05.16.2024
- Enabled sheathing, cladding, ridge cap and labels for dual pitch trusses.
- Updated the polynesian truss so layers and materials are properly assigned.
- Enabled the "Edit Truss Assembly" function for dual pitch trusses (imperial and metric units).
- Enabled the "Edit Truss Assembly" function for polynesian trusses (imperial and metric units).
- Enabled the "Edit Truss Assembly" function for bowstring trusses (imperial and metric units).
- Enabled the "Edit Truss Assembly" function for bow barrel trusses (imperial and metric units).
The edit and regen functions have now been enabled for all active truss types within the plugin. However I still have four truss types that need to be setup and activated.
