    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 12.2k Views 11 Watching
    • jo-keJ Offline
      jo-ke
      @solo said:
      That is way cool, can you get multiple views of the same image? or will the AI create a different reult for different views?
      that's the typical AI problem, always different results.
      I hope there will be more control in the future.
      Stable diffusion has controlnet, a good tool to create consistant pictures but I have no idea to use it together with sketchup.
      Maybe in the future there will be more development
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        @l i am said:
        Very cool Jo-ke, if you used/use prompts, would you mind posting the prompt? Would be very helpfull ๐Ÿ‘
        I've used very simple prompts like: ultrasharp photography of a modern dining room in beige and blue colors, tropical garden outside"
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          still testing the options....
          I just started to combine render and AI.
          rendering cloth in wardrobes has really bad results, because of low resolution models. If I would take better models for cloth the filesize would rise enormously.
          AI does really a goof job in makeing realisic cloth and a bad job in doing the rest in desired materials and colors.
          so I took my render with the right setting for my wardrobe and took the cloth of the stablediffusion output and merge them in Photoshop:
          unfortunately I can't export my POV Camera to twinmotion. this would be helpfull for later work in photoshop
          su view
          stable diffusion
          twinmotion
          merging AI and render in Photoshop
          http://www.zz7.de
            Wow the first one is so impressive ๐Ÿ‘ Scarily so ๐Ÿ˜‰
            • ntxdaveN Offline
              ntxdave
              Yup!
              Press F1...thank me later
              • jo-keJ Offline
                jo-ke
                another one. diffusion is the loser in this case.
                this time twinmotion wins.
                all renders optimised in photoshop
                su
                twinmotion
                twilightrender
                su diffusion and stable diffusion
                http://www.zz7.de
                  Why not try the Free Vizcom online ?
                  So easy to use! ๐Ÿ˜Ž And the first on this concept domain...
                  Team of 2 persons in free!
                  No limit of number images
                  Only limit is one image proposition by render (Pro 4)
                  From your image B&W
                  But you can import a 3D model... (obj format)
                    you can of course all detail...or modify by prompt...
                    InPainting (G)
                    • jo-keJ Offline
                      jo-ke
                      hmmm. I think su diffusion does a better job, what I can see.
                      http://www.zz7.de
                        from your 2D image &W
                        https://images2.imgbox.com/14/20/NWz7BtHs_o.gif
                          Seems there is no change between original and render ...
                          https://images2.imgbox.com/50/66/N2FRQxzc_o.gif
                          • jo-keJ Offline
                            jo-ke
                            This one looks better.
                            My general problem with AI is, that I have to less control over the result.
                            In my case, I want to sell a shelf or a wardrobe and it has to be a consistant look.
                            But AI does a wonderfull job in textiles and Lightning.
                            So I am trying to combine them in Photoshop.
                            http://www.zz7.de
                              Yep even some ai accept 3D input files i am quasi sure this 3D is translated in 2D before any process... in some months maybe this will be changed...
                              • jo-keJ Offline
                                jo-ke
                                mixing AI and render in photoshop is a really good workflow:
                                especially the textiles come out much better
                                render
                                ai
                                mix
                                http://www.zz7.de
                                  Have you try Krea ai or Magnific ai for enhance the first ai result ?
                                  (Magnific ai has not try version) ๐Ÿ˜ฎ
                                  • jo-keJ Offline
                                    jo-ke
                                    the pic above is the plain output of Sketchup Diffusion.
                                    Sometimes I am using Stable diffusion to develop the pics further.
                                    Stable Diffusion is a strong tool with many options to change the style and details of any pictures.
                                    I didn't try the apps you mentioned
                                    http://www.zz7.de
                                      Very interesting thread jo-ke ๐Ÿ‘ So from what I understand you use sketchup diffusion and then put it through Stable diffusion? Could you please give examples of your prompts agian? I mean prompts for the bookcase room divider Prompts into Su diffusion and then how you did the enhancment in SD. I certainly seems the best sulution by the look of those images. And I think this is early days for AI. Seems you and and Pilou are ahead of the pack. I don't/did not like the concept of AI but that is Dinosaur thinking. Embrace it or become ectinct ๐Ÿ˜‰
                                        From your little "ai render" in the free Krea !
                                        https://images2.imgbox.com/b4/39/sqqjujl9_o.gif
                                        Krea images are given in PNG (transformed here in jpg for less size!
                                        https://images2.imgbox.com/7c/94/dMftW6rB_o.jpg
                                        https://images2.imgbox.com/ec/81/VdknclQx_o.jpg
                                          From the little pure "render" in the Free Krea
                                          https://images2.imgbox.com/9b/b7/IhvqQHIN_o.gif
                                          https://images2.imgbox.com/cd/5f/Jj1pQCh7_o.gif
                                          https://images2.imgbox.com/af/45/pazWaPFq_o.jpg
                                            From the little "mix" inside the free Krea
                                            (the before / after is made directly by Krea )
                                            Ps Magnific is even better (but can't try it...
                                            https://images2.imgbox.com/0a/48/cfvzjbQT_o.gif
                                            https://images2.imgbox.com/03/24/uxUyg6h9_o.jpg
                                            • 1 / 5
