    Playing arround with Sketchup diffusion
    99 Posts 11 Posters 8.7k Views 11 Watching
    • jo-keJ Offline
      jo-ke
      here a test with interior design:
      and an additional pic with twinmotion
      sketchup diffusion
      stable diffsuion
      Twinmotion
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        and a tramwaymodel:
        SU
        sketchup diffusion
        stable diffusion
        http://www.zz7.de
        • soloS Offline
          That is way cool, can you get multiple views of the same image? or will the AI create a different reult for different views?
            Very cool Jo-ke, if you used/use prompts, would you mind posting the prompt? Would be very helpfull ๐Ÿ‘
            • jo-keJ Offline
              jo-ke
              that's the typical AI problem, always different results.
              I hope there will be more control in the future.
              Stable diffusion has controlnet, a good tool to create consistant pictures but I have no idea to use it together with sketchup.
              Maybe in the future there will be more development
              http://www.zz7.de
              • jo-keJ Offline
                jo-ke
                I've used very simple prompts like: ultrasharp photography of a modern dining room in beige and blue colors, tropical garden outside"
                http://www.zz7.de
                • jo-keJ Offline
                  jo-ke
                  still testing the options....
                  I just started to combine render and AI.
                  rendering cloth in wardrobes has really bad results, because of low resolution models. If I would take better models for cloth the filesize would rise enormously.
                  AI does really a goof job in makeing realisic cloth and a bad job in doing the rest in desired materials and colors.
                  so I took my render with the right setting for my wardrobe and took the cloth of the stablediffusion output and merge them in Photoshop:
                  unfortunately I can't export my POV Camera to twinmotion. this would be helpfull for later work in photoshop
                  su view
                  stable diffusion
                  twinmotion
                  merging AI and render in Photoshop
                  http://www.zz7.de
                    Wow the first one is so impressive ๐Ÿ‘ Scarily so ๐Ÿ˜‰
                    • ntxdaveN Offline
                      ntxdave
                      Yup!
                      Press F1...thank me later
                      • jo-keJ Offline
                        jo-ke
                        another one. diffusion is the loser in this case.
                        this time twinmotion wins.
                        all renders optimised in photoshop
                        su
                        twinmotion
                        twilightrender
                        su diffusion and stable diffusion
                        http://www.zz7.de
                          Why not try the Free Vizcom online ?
                          So easy to use! ๐Ÿ˜Ž And the first on this concept domain...
                          Team of 2 persons in free!
                          No limit of number images
                          Only limit is one image proposition by render (Pro 4)
                          From your image B&W
                          But you can import a 3D model... (obj format)
                            you can of course all detail...or modify by prompt...
                            InPainting (G)
                            • jo-keJ Offline
                              jo-ke
                              hmmm. I think su diffusion does a better job, what I can see.
                              http://www.zz7.de
                                from your 2D image &W
                                https://images2.imgbox.com/14/20/NWz7BtHs_o.gif
                                  Seems there is no change between original and render ...
                                  https://images2.imgbox.com/50/66/N2FRQxzc_o.gif
                                  • jo-keJ Offline
                                    jo-ke
                                    This one looks better.
                                    My general problem with AI is, that I have to less control over the result.
                                    In my case, I want to sell a shelf or a wardrobe and it has to be a consistant look.
                                    But AI does a wonderfull job in textiles and Lightning.
                                    So I am trying to combine them in Photoshop.
                                    http://www.zz7.de
                                      Yep even some ai accept 3D input files i am quasi sure this 3D is translated in 2D before any process... in some months maybe this will be changed...
                                      • jo-keJ Offline
                                        jo-ke
                                        mixing AI and render in photoshop is a really good workflow:
                                        especially the textiles come out much better
                                        render
                                        ai
                                        mix
                                        http://www.zz7.de
                                          Have you try Krea ai or Magnific ai for enhance the first ai result ?
                                          (Magnific ai has not try version) ๐Ÿ˜ฎ
                                          • jo-keJ Offline
                                            jo-ke
                                            the pic above is the plain output of Sketchup Diffusion.
                                            Sometimes I am using Stable diffusion to develop the pics further.
                                            Stable Diffusion is a strong tool with many options to change the style and details of any pictures.
                                            I didn't try the apps you mentioned
                                            http://www.zz7.de
                                            • 1 / 5
